STP Issue
often we are receiving the STP change logs from the L2 switch and we could see flap in uplinks. We are getting log below.
    %SFF8472-3-THRESHOLD_VIOLATION: Gi1/1/1: Rx power low warning; Operating value: -18.2 dBm, Threshold value: -16.9 dBm.
    %SFF8472-3-THRESHOLD_VIOLATION: Gi3/1/1: Rx power low warning; Operating value: -17.3 dBm, Threshold value: -16.9 dBm.
ICANG
Frequent Visitor
Frequent Visitor
First of all can you please check what kind of fibre cable and sfp module do you use ? Something like single mode or multimode.? If wrong can you please fix and check again?
Apart from that error message could be due to one of the following;
Bad fiber or  Bad transceiver module
As an another action plan;
1-) You can replace the fiber link all over the path .
2-) You can try to replace the transceiver module on both side .
Thank you
Best Regards
PS: Please don't forget to rate if it's helpful
Mark Elsen
 - Probably software bug, ignore if no effective connectivity problems are seen
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
ICANG
Frequent Visitor
Frequent Visitor
Thank you
Best Regards
Hi ,
   Awaiting for the customer reply.
balaji.bandi
If this was working for long you see suddenly?
in that switch only 2 ports having issue rest all ok.
i would inspect physical patch cable and replace SFP and test again and monitor
BB
