stp optimize bpdu
claude1968
I want to know why sometimes I see
no spanning-tree optimize bpdu transmission
in pvst configuration?
Francois Tallet
Level 7
Level 7
It's a bug. This is supposed to be a hidden CLI for troubleshooting purposes. If you have upgraded since this command appeared on your configuration, try the "spanning-tree optimize bpdu transmission" in global config to see if it goes away. If not, you can ignore (I would probably not upgrade just to get rid of that).
Francois
