MAC Address on Cisco Serial Port
keeleym
Level 5
Level 5
Hi All
Just wondering how we are able to get serial ports on a Cisco router to communicate via TCP/IP when there appears to be no MAC address on the serial port of a Cisco Router?
R_ACCESS_1#sh int
FastEthernet0/0 is up, line protocol is up
Hardware is AmdFE, address is 000d.2999.2320 (bia 000d.2999.2320)
Serial0 is up, line protocol is up
Hardware is HD64570
Description: LINK TO MSC2
MTU 1500 bytes, BW 128000 Kbit, DLY 20000 usec,
Encapsulation X25, loopback not set
Where does the Serial MAC address come from?
Best Regards,
Michael
Anyone can correct me if i am wrong.
There is no MAC used in the WAN network.
As MAC works on layer 2 the same way you need to configure the encapsualtion which would work on layer 2.
It can be HDLC or PPP thats the reason how the latyer 2 communcation takes place. If you do not configure the Encapsulation this would not work.
The best example would be the technology Frame-relay its a layer 2 but works on wan without any MAC address.
Pravin Phadte
Level 5
Level 5
Serial link does not use MAC address.
Encapsulation X25 is the layer 2 protocol which is used in this setup to communicate.
Hi There
The snippet of Serial interface configuration I used above was probably a bad axample as this link is indeed configured for XOT. However even if I configure a serial interface with an IP address and connect it to another routers serial interface,
Here is a print out form just such a set up
R1-7206VXR#sh int s1/0
Serial1/0 is up, line protocol is up
Hardware is M8T-X.21
Internet address is 172.16.4.1/24
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
Encapsulation HDLC, crc 16, loopback not set
R2-7206VXR#sh int s1/0
Internet address is 172.16.4.2/24
And still there is no MAC address on the interface. So I am wondering how IP connectivity is working?
Even capturing ping traffic between the two routers does not show a MAC address and I am confused as to how this works.
Best Regards,
Michael
Hi There
That makes sense. Cheers for the response and clarification.
Best Regards,
Michael
