STP portfast configuration
Zigmunds Vitins
I have two blade system's with ESXi hosts on few servers, all ESXi servers are connected to two cisco switch in blade enclosure.
Both ESXi adapters are in active mode.
All ports on the blade switch are configured as trunk with several vlan id (same vlan id are on vSwitch's)
When I do migration from one server to another my network on virtual server stops working.
I disconnect network adapter in vm settings and connect it back - then all is fine again.
I tried change vm network to different vlan idand then back - also helps.
In vmware forum I get recommendation, that I have to enable port-fast on all my Cisco ports.
What is correct way to do it?
Thanks.
Zigmunds
IAN WHITMORE
Level 4
Level 4
On the interfaces connected to server you should configure:
#spanning-tree portfast trunk
HTH,
Ian
IAN WHITMORE
Level 4
Level 4
HTH,
Ian
Thanks.
Zigmunds
