STP Priority on 3750
r.subramani
Hi All,
I have a Cisco 3750 switch on which I am seeing the bridge priroty to be 49152. The default bridge priority has not been changed as seen from the running configuration given below -
version 12.2
no service pad
service timestamps debug uptime
service timestamps log datetime localtime
hostname Switch
enable password 7 XXXX
aaa new-model
vtp mode transparent
no ip subnet-zero
ip domain-name lehi.micron.com
ip name-server 10.192.88.4
ip name-server 10.192.88.6
no file verify auto
spanning-tree mode pvst
spanning-tree uplinkfast
vlan internal allocation policy ascending
vlan 10,100
interface Vlan1
no ip address
no ip route-cache
no ip mroute-cache
shutdown
interface Vlan100
description dbsn
ip address 10.192.100.9 255.255.254.0
no ip redirects
no ip route-cache
no ip mroute-cache
ip classless
no ip http server
Switch#sh spanning-tree vlan 10
VLAN0010
  Spanning tree enabled protocol ieee
  Root ID    Priority    49162
             Address     001e.7a50.e100
             This bridge is the root
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
Bridge ID  Priority    49162  (priority 49152 sys-id-ext 10)
             Aging Time 300
  Uplinkfast enabled
Interface        Role Sts Cost      Prio.Nbr Type
Te1/0/1          Desg FWD 3002      128.29   P2p
Te1/0/2          Desg FWD 3002      128.30   P2p
Switch#sh sp
Switch#sh spanning-tree vlan 100
VLAN0100
  Root ID    Priority    24676
             Address     0022.9060.69c0
             Cost        3002
             Port        29 (TenGigabitEthernet1/0/1)
  Bridge ID  Priority    49252  (priority 49152 sys-id-ext 100)
             Aging Time 300
  Uplinkfast enabled
Te1/0/1          Root FWD 3002      128.29   P2p
Switch#sh ver
Cisco IOS Software, C3750E Software (C3750E-UNIVERSAL-M), Version 12.2(35)SE5, R
ELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 16:17 by nachen
Image text-base: 0x00003000, data-base: 0x01C00000
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750E-HBOOT-M) Version 12.2(35r)SE1, RELEASE SOFTW
ARE (fc2)
Switch uptime is 1 week, 6 days, 18 hours, 43 minutes
System restarted at 15:11:11 MST Thu Nov 18 2010
System image file is "flash:c3750e-universal-mz.122-35.SE5/c3750e-universal-mz.1
22-35.SE5.bin"
License Level: ipservices   Type: Permanent
Next reboot license Level: ipservices
cisco WS-C3750E-24TD (PowerPC405) processor (revision D0) with 245760K/16376K by
tes of memory.
Processor board ID CAT1147W09G
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
28 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Switch   Ports  Model              SW Version              SW Image
*    1   30     WS-C3750E-24TD     12.2(35)SE5             C3750E-UNIVERSAL-M
Configuration register is 0xF
I understand that the default priority is 32768+VLAN ID. Can any of check and see if I am missing something?
Thanks.
Peter Paluch
The increased STP priority is caused by configuring the UplinkFast feature. Whenever you configure the UplinkFast, the switch priority will be raised automatically to 49152. Read more about the command and the UplinkFast feature here:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_55_se/commmand/reference/cli3.html#wp2500731
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_55_se/configuration/guide/swstpopt.html#wp1031144
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a0080094641.shtml
Best regards,
Peter
5 Replies 5
cadet alain
You're right default priority is 32768  but enabling uplinkfast will set priority to 49152.
Regards.
Seems we've both "attacked" the same thread. Thanks for your reply!
Best regards,
Peter
Peter Paluch
Best regards,
Peter
Hi Peter,
quicker than you on this one
Kind regards.
Alain.
Thanks all! That was helpful.
