stp problem
Kashish_Patel
Level 2
Level 2
I am seeing two different switches claiming themselves to be spaning tree root for the same vlan (using same mac address). Can anybody please explain how this is possible?
Switch1#sh spanning-tree vlan 192
Spanning tree instance for vlan 192
VL192
  Spanning tree enabled protocol rapid-pvst
  Root ID    Priority    32960
             Address     001c.7319.9d54
             This bridge is the root
  Bridge ID  Priority    32960  (priority 32768 sys-id-ext 192)
             Hello Time  2.000 sec  Max Age 20 sec  Forward Delay 15 sec
Switch2#sh spanning-tree vlan 192
VL192
7 Replies 7
benjammin
This may be a silly question, but are the switches connected? Are they allowing the vlan to traverse the connection? Are you using VTP? What's the output of 'sh vtp status' of both switches?
Rolf Fischer
Level 9
Level 9
If all the switches use the default priority (0x8000 / 32768), the MAC-address is needed as the tie-breaker.
MAC-Adresses of course should be unique, otherwise with default configruration there is no tie-breaker and the bridges remain claiming themselves as rootbridges (no superior BPDU received).
Are that real switches or is it a simulation (packettracer, gns3)?
What about the other VLANs; do they also have the same MAC-Adresses?
Rolf
milan.kulik
Level 10
Level 10
if you issue "show version" on the switches, do they both show the same Base ethernet MAC Address?
BR,
Milan
They show different mac addresses.
001c.7319.9d54 is shown on switch1..switch2 shows different mac
how are the switches connected each to the other?
Aren't they in stack, e.g.?
BR,
Milan
Switches are connected to each other, but they are not in stack.
I think it's because of mlag. thanks for your help!
Oh, you are running MLAG there?
What kind of switches are those?
7600s?
BR,
Milan
