06-26-2008 01:34 AM - edited 03-05-2019 11:50 PM
Hi there,
As I know the STP root port is a switch port with the lowest cost to the root bridge. The the Switch has to choose between 2 ports witch equal cost to the root, to port with the lower ID becomes the root. PortID=priority.number (ex: 128.7).
In my lab setup the port with the lowest ID dows't become the root. Why? Do I miss something? Could it be a bug or something?
I am running Spanning tree enabled protocol ieee
The setup is as follows:
sw1(f0/1)----------------(f0/1)sw2
(f0/2) . (f0/2)
(f0/2) . (f0/1)
sw4(f0/1)--------------- (f0/2)sw3
The sw4 is the root and the blocking port should be f0/2 of SW2 and not f0/1 of sw2 (as it is as shown by sh spanning-tree command).
##########################3
sw4#sh spanning-tree
VLAN0001
Root ID Priority 24577
Address 000c.3055.abc0
This bridge is the root
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 24577 (priority 24576 sys-id-ext 1)
Aging Time 300
Interface Role Sts Cost Prio.Nbr Type
Fa0/1 Desg FWD 19 128.1 P2p
Fa0/2 Desg FWD 19 128.2 P2p
sw3#sh spanning-tree
VLAN0001
Cost 19
Port 2 (FastEthernet0/2)
Bridge ID Priority 32769 (priority 32768 sys-id-ext 1)
Address 000a.4153.ca40
Aging Time 300
Fa0/2 Root FWD 19 128.2 P2p
sw1#sh spanning-tree
VLAN0001
Cost 19
Address 000a.418b.d380
Aging Time 300
sw2#sh spanning-tree
VLAN0001
Cost 38
Address 0008.a34e.6780
Aging Time 300
Fa0/2 Root FWD 19 224.2 P2p
Fa0/1 Altn BLK 19 16.3 P2p
06-26-2008 01:50 AM
The port priority is not taken from the local switch port configuration, it is taken from what is received from the remote switch.
Ie,
Root Switchport1 -------Switch A port1
Root Switchport2 -------Switch A port2
By default port1 on SwitchA will be root port, if you want to use the port priority to effect the stp and have Switch A use port2 instead, then you need to change the port priority on the Root switch port2, ie spanning-tree vlan X port-priority 64 (default is 128)
Now do show spanning-tree interface port2 detail on Switch A and it will show the received value of 64 on port 2, compared to 128 on port 1.
So in your case you need to verify what priority you are received from the root on your two ports.
Hope this helps.
Cheers,
LR
