STP with Gig links
jagdev.dhaliwal
Hi All,
Is there any diffrence between, the link cost of 3gig and 8 link etherchannel
100 Mbps 19 Fast Ethernet
200 Mbps 12 Fast EtherChannel
300 Mbps 9 Fast EtherChannel
400 Mbps 8 Fast EtherChannel
500 Mbps 7 Fast EtherChannel
600 Mbps 6 Fast EtherChannel
700 Mbps 5 Fast EtherChannel
800 Mbps 5 Fast EtherChannel
1 Gbps 4 Gigabit Ethernet
2 Gbps 3 Gigabit EtherChannel
10 Gbps 2 10G Ethernet
20 Gbps 1 20G EtherChannel
40 Gbps 1 40G EtherChannel
I found the above information, so not sure if there will be any cost diffrence between 3 Gig and 8 Gig.
Jagdev
Peter Paluch
Hello Jagdev,
To be honest, there is only a little chance that the STP port cost of a 3Gbps port would be different to the cost of an 8Gbps port using the so-called short port cost method based on 802.1D-1998.
However, does your switch support the spanning-tree pathcost method long command? If it does, it will activate the port cost method as defined in 802.1D-2004:
100 Mbps ~ 200,000
1 Gbps ~ 20,000
10 Gbps ~ 2,000
etc.
In general, 802.1D-2004 cost = 20,000,000 / (bandwidth in Mbps)
Best regards
Peter
Peter Paluch
Hello Jagdev,
100 Mbps ~ 200,000
1 Gbps ~ 20,000
10 Gbps ~ 2,000
etc.
Best regards
Peter
Thanks Peter,
