STP
jain.manish94
Please can someone tell me meaning of each line.
Port 257 (GigabitEthernet3/1) of VLAN0102 is designated forwarding
Port path cost 4, Port priority 128, Port Identifier 128.257.
Designated root has priority 4198, address d0c7.89a9.c940
Designated bridge has priority 4198, address d0c7.89a9.c940
Designated port id is 128.257, designated path cost 0
Timers: message age 0, forward delay 0, hold 0
Number of transitions to forwarding state: 1
Link type is point-to-point by default
BPDU: sent 427353, received 3
125 Replies 125
Giuseppe Larosa
Hello Jain,
the output is taken from show spanning-tree gi3/1 detail.
The section of output applies to Vlan 102.
257 is the SNMP ifindex of interface gi3/1 is an internal identity of the port. The port is in Designated Forwarding state means it is in forwarding state for STP for instance running in Vlan102 because the port has been elected as the Designated port in the segment.
The STP cost of a GE port is 4 with short metric, the port priority is a priority assigned to the port 128 is the default value. The port identifier is the result of putting together  port priority and port ID (SNMP ifindex 257 see above).
the root bridge for Vlan102 STP instance has bridge priority 4198 = 4096+102, the switch is using extended system-id also known as MAC address reduction. the root bridge MAC address is d0c7.89a9.c940
the bridge-id of the Designated bridge for the segment pleaese note is the same as the line before, this means the local switch is the root bridge for Vlan 102
the designated port for the segment is gi3/1 that is identified by 128.257 priority.SNMP ifindex.
the designated path cost is 0 because this switch is indeed the root bridge so the accumulated cost to the root bridge is 0.
>> this is not clear to me I would expect values different from 0, but it may be related to the Rapid STP type running on the switch.
the port transitioned to STP fowarding state only one time
this may indicate the switch is running Rapid PVST and not PVST+ as the point-to-point link concept has been introduced with Rapid STP.
except 3 BPDUs received  this port is sending out regularly STP BPDUs for STP instance in vlan102.
Hope to help
Giuseppe
Thanks for your reply. Please tell me also.
how 257 value is calculated or by default because i see 358 398 also. how these value are coming
Hello Jain,
as far as I know SNMP ifindex is calculated at boot time and each interface should get a value.
In some platforms there is a feature called SNMP ifindex persist that allows to use the same values across reloads but it is not guaranteed when performing updates.
The problem of SNMP ifindex consistency involves SNMP gets from management systems NME and also other features like Netflow that use the ifindex to describe the interface.
In any case, you cannot assign the SNMP ifindex you can only achieve persistency across reloads with appropriate commands on supported platforms.
Hope to help
Giuseppe
ok , suppose in my network there is looping in that case what i check to solve this problem..
this command helps trace a loop , start at core and follow the constant most recent occurring changes
show spanning-tree detail | inc ieee|occurr|from|is exec
what i will get here.... i mean after putting this command what i need to follow...
so example from switch below of the output , shows a change occurred 17 mins  coming from port g2/0/10 , then I would do a show cdp neighbour see whats connected to that poort , jump onto the switch connected and run the command again , STP changes should not be occurring frequently so there usually easy enough to follow , this will eventually bring you to the port that may be causing it , whether its faulty , lose cable or bad device attached
VLAN0001 is executing the ieee compatible Spanning Tree protocol
  Number of topology changes 5674 last change occurred 17:35:34 ago
          from GigabitEthernet2/0/10
Thank you mark/Giuseppe
Please can you tell me also about MPLS basic configuration how to apply when to apply and where to apply
Yes I know MPLS you only configure that if your an ISP provider like BT or AT & T really
Its all service provider how they switch there customer traffic across their networks and what they use to do it at layer 2
If your not an ISP you should only really be configuring BGP on your CE customer edge equipment and not even see MPLS
MPLS is a service you buy from the ISP rather than using the internet they dedicate your traffic across their global networks
Please mark can you help me actually in interview they ask about MPLS , what i say can you tell me more so i can clear interview. it will be help for me.
i have knowledge in BGP but what i say when they ask about MPLS
can you share some more information like
configuration
There's no point me just stating config if its an interview they will catch you out straight away like that  , this video below is clear and easy to understand you should try learn it you will come across a lot better
https://www.youtube.com/watch?v=--IHeAdipHk
ok , can i ask some more question about HSRP if you don mind...
yes go for it
Suppose on one core switch
SW1# int vlan 100
standby 11 ip 10.1.100.1
standby 11 priority 110
standby 11 preempt
on second switch
SW2# int vlan 100
standby 11 preempt
suppose here sw1 down ok , by default it will decrese self value from 110 to 100 ok , how will sw2 become active because
sw2 also have 100 by defualt.
