Strange errors in 6513
Colin Higgins
Level 7
Level 7
I have two 6513s configured in a VSS-SSO pair. These switches provide power to Cisco IP phones (various models).
I am seeing an error that says
C6K_POWER_SW1-4-PD_NOLINKUP: The device connected to 20/25 is powered up but its link is not up in 5 seconds: Therfore, power is withdrawn for the port
There isn't even a port 20/25 on the switch!
What is this?
Jose Solano
Level 9
Level 9
I see you have questions regarding the error message (C6K_POWER-SW1-4-PD_NOLINKUP The device connected to 20/25 is powered up but its link is not up in 5 seconds. Therefore, power is withdrawn from the port)
The 20/25 is referring to the Virtual slot mapping with VSS. Can post the show tech? Or can you look up on the show tech the field --- test platform software switch virtual vslot table --- and posted?
