Strange Issue, pls require expert opinion
illusion_rox
Hi all, i am facing a strange issue in my enviornment, my router suddenly stops reaching specific IPs !! i mean when i try to ping them, traceroute them, no response !! after reloading the router everything goes ok !, this issue arised in 4 routers in my environment, 1 is 3845, 3 are 1841s, the issue is solved on 3 routers (1 3845, 2 1841), however my 1 branch is still facing this issue that router stops communicating with a particular ip, this is what i have done to rectify the issue,
my router stopped pinging the DSL connection so i placed a laptop on the same port which is Fa0/0/3, member of vlan 3,
1) i assigned the same ip that was of DSL modem to laptop and then tried to ping but no response, in debug i am seeing packets are being sent, via FIB, but no response,
2) arp entries are ok, i checked the mac-address of laptop and it was ok.
3)i changed the subnet of vlan 3 and then tried but no response,
i reloaded the router and everything got up and fine !!,
What do you guys suggest, pls guide me
satyamothukuri
check any ip conflict in your network.
