Strange Issue
Ibrahim Jamil
Level 6
Level 6
Hello
Pls Have a look to attached
am able to telnet to the CORE from my LAN but nothing appears on my terminal emulation
5 Replies 5
N W
have you tried another program such as putty, or telent from the command line or CRT just to rule out the program. Can you tell net to other devices ok? Can you try from a different ip address/PC?
I Found all vty line busy and no body is connected since long,Why is that?
add a time out to the VTY ports to disconnect unused sessions
How to configure that
line vty 0 4
  exec-timeout xxx
Hope this helps
Noel
