PBR with Cisco VSS
Ahmed Shahzad
I am trying to configure PBR on SVI of Cisco VSS but it is not working:
IOS version is:
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(33)SXH6, RELEASE SOFTWARE (fc1)
Configuration is given below:
access-list 20 permit 10.153.5.41 // trying to define another default gateway for this appliance.
route-map PBR_WSA permit 10
match ip address 20
set ip default next-hop 10.154.16.1
int vlan 3005
ip policy route-map PBR_WSA
Please note that there is a default route exist in the routing table.
Can you guide me where is the prbolem; either it is a bug or issue in configuration.
Best Regards,
Shahzad.
mshahzad@hotmail.com
Thanks Jon.
I have tried both options set ip default next-hop and set ip next-hop but it does not work.
Please note that I want packet route using routing table except default route and then the PBR.
Any idea how to achieve it.
How are you verifying it doesn't work ? Some people simply check the acl for hitcounts but because of hardware switching you often don't see hitcounts. Are you tracerouting to the destination ?
As for use routing table (except default-route) and then PBR as far as i know you can't do this. You either use the routing table (including default-route) and then PBR or use PBR and then routing table. So the only way to use the routing table first and then PBR would be to remove the default-route and include all the other traffic in your PBR config ie. send the traffic for your specific host to one next-hop and then send all other traffic to another next-hop. This would work fine if you only had the one L3 vlan interface eg. vlan 3005 in your example, but i suspect on your 6500s you have many other L3 vlan interfaces and they use the default-route as well ?
So when you say it isn't working do you mean PBR isn't working at all or just that you cannot get it to use routing table (without default) and then PBR ?
If it isn't working at all then i can't see anything wrong with your config although i usually use extended acls in the PBR config because i have seen issues sometimes when you don't.
Jon
Jon Marshall
Shahzad
"set ip default next-hop" means use the routing table first and if there is no route then use the next-hop configured with PBR. But because you have a default-route in the routing table there is a route to the destination and this will be used.
You need to use "set ip next-hop" which means use PBR before consulting the routing table.
Jon
Thanks Jon.
Thanks Jon.
Jon
Ahmed Shahzad
Thanks Jon,
I am checking counts on "show route-map PBR_WSA" and could not found any hit.
There are number of SVIs and the requirement is one host behind an SVI use routing table (except default route) and a customize L3 interface for all other traffic.
Best Regards,
