Strange output drops on 3120 cisco HP blade
fcoppotelli
I've a strange command output on a catalyst blade HP 3120 about the output drops.
When I issue the command show interface I see the following:
SWNCL6#sh int g2/0/2
GigabitEthernet2/0/2 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 58bf.ea80.1882 (bia 58bf.ea80.1882)
  Description: ESX4-01
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:02, output hang never
  Last clearing of "show interface" counters 5d13h
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 3499518407
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 118000 bits/sec, 118 packets/sec
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     53447323 packets output, 6453499563 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
If I immediately repeat the command after 1 second I see another value:
SWENCL6#
SWENCL6#
SWENCL6#
SWENCL6#
SWENCL6#sh int g2/0/2
  Last input never, output 00:00:03, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 37576
This happens all the times I give the command. The interface connects the blade to the core switch (Catalyst 6509) and the running IOS is the following:
WS-CBS3120X-S      12.2(58)SE1           CBS31X0-UNIVERSALK9-M
I think the possible cause could be a bug on the version but I didn't find anything on cisco website and the release 12.2(58)SE1 sems to be the last one for that hardware.
Anyone have suggestions?
Fabio
Reza Sharifi
Usually, output drops are not an IOS bugs/issues.
have a look at this link for some troubleshooting tips.
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080094791.shtml#topic4
I give the command:
show int g2/0/2
and I have the following value about the total output drops
I repeat the command after 3 seconds:
If I had a problems on the interface I should see the first value increased, that's why I was thinking about a IOS bug
12.2(58)SE1
Could be an IOS bug because this version is very buggy.
If you can, use 12.2(55)SE8 and observe.
Devroy Peterson
Hi, this is probably late, but the software counters for output drops on these types of switches (3750's, blade switches) are not reliable.
What you need to check is "show platform port-asic statistics drop" for a reliable drop counter on an interface. This will give you the hardware counters
https://tools.cisco.com/bugsearch/bug/CSCtq86186/?reffering_site=dumpcr
Switch stack shows incorrect values for output drops/discards
on show interfaces. For e.g.,
--- show interfaces ---
GigabitEthernet2/0/5 is up, line protocol is up (connected)
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 4294967163
Conditions:
This is seen on Stackable switches running 12.2(58)SE or later.
Workaround:
None.
