Hi All
I currently have a router on a stick and I want to create a sub interface
int g0/0/0.49
encapsulation dot1q 49
on the switch this port connects to I have
switchport mode trunk
switchport trunk allowed vlan 49
now on the same switch there is another port that goes off to another switch. (this is an isolated network with one vlan needed only)
vlan 49
this is then connect to a stack of 2 3750's
vlan 49
int g2/1/14
int g1/1/14
Description connectionto 2960
This now goes down
to a lonesome 2960
vlan 49
int g1/0/24
interface vlan 49
ip address 192.168.1.254
laptop connects to
int g1/0/24
switchport mode acces
switchport access vlan 49
IP default-gateway 192.168.1.1
Naturally you would expect destination host unreachable
My theory is should all the ports (except the ones between the router and the switch) be configured as access ?
If not what would be the solution to get the laptop hanging off the access port on the 2960 talking
ip address 192.168.1.5 255.255.255.0 gateway 192.168.1.1
Thanks in advance
Not sure I follow.
If you set default gateway for the laptop to be 192.168.1.1, you have vlan 49 created on all the switches and you allow it on all the trunk links then it should work.
Is it not ?
Jon
No it doesn't, I removed access-list rules off the 2960 aswell
It should work as you have it.
So like I say, vlan 49 must exist in the vlan database on all switches, your trunk links must be up and you must allow vlan 49 on all the trunk links.
Then as long as the access port for the laptop is in vlan 49 and you have set the default gateway to be 192.168.1.1 you should be able to ping it.
Jon
