Stuck at Factory Reset on a Catalyst 3850
Hello.
I'm performing a factory reset on a 3850. Followed steps in this forum. Removed old configuration, but now, after reboot, It gets stuck here:
% Checking backup nvram
% No config present. Using default config
Both ignore startup configuration and disable password are set
This will result in erasing the startup config
Do you want to Erase the config? Default: n, Answer y/n:
Doesn't accept any input and just gets stuck here, and never gets the switch prompt.
Guidance is highly appreciated.
Alex
marce1000
                  - Verify sanity of operating-terminal  , by using on other switch console connection.
 M.
Leo Laohoo
That's not a factory reset.
The correct factory reset for IOS-XE is to use the command "factory-reset all" and then use the USB stick to load the firmware packages back into the switch using the command "emergency-install usbflash0:filename.bin".
