Stuck in ROMMON
lamav
Level 8
Level 8
My site tech fumbled the IOS upgrade on a 3750 switch and now its stuck in ROMMON>
I cant find the link to the Cisco document that discusses troubleshooting a 3750 switch that is stuck in ROMMON -- including ROMMON commands.
Anyone have any off hand?
Mark Yeates
Level 7
Level 7
Victor,
Here is a guide to help you on your switch. Although it doesn't say 3750 It will still work for you.
http://www.cisco.com/en/US/products/hw/switches/ps628/products_tech_note09186a0080169696.shtml#topic2
HTH,
Mark
Mark's reference should work (and it does note the 3750).
One extra hint, when doing xmodem, select xmodem1k if available with your client.
