Stuck on an %SW_DAI-4-INVALID_ARP problem
StevenBerchem
My experience in configuring switches and routers is limited and I am stuck on 2 issues with my new Catalyst 1000 switch which I believe are related:
  1. ARP inspection errors
  2. Failure to ping other hosts on the same switch in the same VLAN 10
The ARP error messages I get are:
  • 022175: *Mar 18 14:15:10.663 UTC: %SW_DAI-4-INVALID_ARP: 1 Invalid ARPs (Req) on Gi1/0/5, vlan 10.([9009.d01b.e427/0.0.0.0/ffff.ffff.ffff/10.0.0.5/14:15:09 UTC Sat Mar 18 2023])
  • 022186: *Mar 18 14:45:21.920 UTC: %SW_DAI-4-INVALID_ARP: 1 Invalid ARPs (Req) on Gi1/0/6, vlan 10.([9009.d01b.e428/0.0.0.0/ffff.ffff.ffff/10.0.0.6/14:45:20 UTC Sat Mar 18 2023])
These are the 2 fixed IP interfaces to my NAS, so that is why they are not showing in the DHCP snooping Binding table:
show ip dhcp snooping binding
MacAddress IpAddress Lease(sec) Type VLAN Interface
EC:24:B8:EF:71:EA 10.0.0.218 2238520 dhcp-snooping 10 GigabitEthernet1/0/31
54:05:DB:FD:68:8B 10.0.0.168 2076963 dhcp-snooping 10 GigabitEthernet1/0/25
98:FA:9B:55:E8:41 10.0.0.254 775548 dhcp-snooping 10 GigabitEthernet1/0/18
Total number of bindings: 3
But I have configured an ACL to cover for those 2 NAS ports:
arp access-list ARP-ACL-Servers
permit ip host 10.0.0.5 mac host 9009.d01b.e427
permit ip host 10.0.0.6 mac host 9009.d01b.e428
I have also attached here the running config of my switch in question. My network setup is realy simple: a router 920 connected to my service provider and 4 main switches connected to this router. The router is handling the inter-VLAN routing.
There is also another problem which I never encountered before when configuring a switch: I cannot reach or ping this NAS (which is on the same VLAN 10) from a host connected to this same switch? When my host PC is connected to another (older Cisco 350 switch) I can reach & ping this NAS just fine (which is connected to the Catalyst 1000 on ports 5 & 6). When I check the arp table on my PC, connected to the new 1000 Catalyst switch, the 2 NAS server IP's are not there. When I connect to the older 350 switch the NAS does show up in the arp table on my PC (and I can reach it again). But when I am connected to the switch via SSH - CLI I can ping and traceroute to the NAS just fine.
I am very sure I am making a big beginner mistake here, but I am at a loss where to look. All the research I have done in this Cisco Community has not pinpointed me where the problem is. The results from my PC arp table tell me it is ARP related and most likely with the arp inspection that I am not so familiar with. I also noticed that the IP address next to the MAC address in the error message is blank, which is probably the immediate cause for the error message. But then why does it work from another switch & why does the new Switch not take the ACL into account?
So, can anybody pinpoint my mistake or give me some guidance on where to look for a solution.
Many thanks in advance,
Steven
this my NOTE
the issue I think after check the config is verify dst-mac with IP
f the dst-mac and IP not list in dhcp snooping then the DAI will drop the packet.
so solution only verfiy the scr-mac not dst-mac and IP
5 Replies 5
ip arp inspection filter ARP-ACL-Servers vlan x <<- this need for static IP Server to make DAI accept ARP from these Server
StevenBerchem
Thanks for your answer and I have just been testing this (have been sick so offline for a while).
I also think there must be something wrong with how I entered the "ip arp inspection filter ... " command.
When I deactivate this line in my config (by executing "no ip arp inspection filter ARP-ACL-Servers vlan 10" I immediately get a stream of messages like "030250: *Apr 8 08:26:01.562 UTC: %SW_DAI-4-DHCP_SNOOPING_DENY: 1 Invalid ARPs (Req) on Gi1/0/5, vlan 10.([9009.d01b.e427/10.0.0.5/0000.0000.0000/10.0.0.99/08:26:00 UTC Sat Apr 8 2023])"
When I reactivate the line in my config "ip arp inspection filter ARP-ACL-Servers vlan 10", these messages about DHCP_SNOOPING_DENY immediately stop. So that seems to indicate that at least the access list is correct and behaves as expected. But my original problem is still there; I still get "030251: *Apr 8 08:27:00.566 UTC: %SW_DAI-4-INVALID_ARP: 1 Invalid ARPs (Req) on Gi1/0/5, vlan 10.([9009.d01b.e427/0.0.0.0/ffff.ffff.ffff/10.0.0.5/08:27:00 UTC Sat Apr 8 2023])".
From your comment, I understand that I need to include the VLAN, but I noted the VLAN 10 of which these servers are part? What am I missing here?
Just as an experiment I changed the line to include all my working VLAN's to see if this changes anything = "ip arp inspection filter ARP-ACL-Servers vlan 10-333" but this is really a shot in the dark, so not expecting a solution from this (amlthough it does include the native VLAN).
Sorry to bother but could you give me another hint on where to look? Kind regards,
Steven
StevenBerchem
Based on this article The "%SW_DAI-4-DHCP_SNOOPING_DENY:" error message is received when configuring the dynamic ARP inspe... - Cisco Community I have also added the command "ip arp inspection trust" on the 2 interfaces to which my servers are connected. The article stated that this was needed for MAC addresses with a static IP (which do not show up in the DHCP binding table). This did have an effect already as now the 10.0.0.5 address shows in the arp table of my PC.
However the ping still does not work and I cannot reach the server through the browser, so there yet.
this my NOTE
StevenBerchem
Just as an additional note - just discovered that the inability to ping my servers was in fact not (entirely) related to the DAI issue; once I removed "switchport protected" command on the 2 ports to my servers all started working again as normal. So additional clean up of my configuration is still needed, but I have already resolved the DAI issue; many thanks for your help!!!
