stuck on routing
k_armstrong
I'm relativey new to Cisco products, but not networking itself.
I have two devices, as laid out below:
   Internet
Cisco ASA 8.2 <---> Cisco 2811
The inside interface of the ASA is 192.168.0.5.  I have a cable connected to the 2811, and on FE0/0, I have the IP of 192.168.0.19 assigned to it.  I can ping between the devices (from the devices) themselves just fine.
The 2811 is a hand me down that we got from another organization tha already had VLAN's configured on it.  I am not allowed to modify any other interface besides FE0/0 due to the equipment that is connected to the other interfaces.
What I am trying to do is get the networks that are attached to the 2811 to be able to communicate with my 192.168.0.0/24 network behind the ASA.  I set up some static routes, modified the ACL to allow all IP traffic (since I couldn't get anything else to work) on the 2811, yet I am still having problems.
Here are my configs for your perusal (security stuff cleared out of course):
The ASA:
[code]
Result of the command: "show run"
: Saved
ASA Version 8.2(5)
hostname cctiforest
domain-name catcomtec2
enable password STUFF encrypted
passwd STUFF encrypted
names
name 10.255.3.0 P25Net1 description P25Net1
name 10.255.2.0 P25Net3 description P25Net3
name 10.255.0.0 P25NetAll
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.0.5 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address X.X.X.X 255.0.0.0
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns domain-lookup inside
dns domain-lookup outside
dns server-group DefaultDNS
name-server 192.168.0.30
name-server X.X.X.X
name-server X.X.X.X
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group service TCP-GoldSync tcp
description GoldSync Service
port-object eq 5993
access-list outside_cryptomap_20 extended permit ip 192.168.0.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list polnat extended permit ip 192.168.0.0 255.255.255.0 192.168.20.0 255.255.255.0
access-list 101 extended permit icmp any any
access-list 101 extended permit tcp any interface outside object-group TCP-GoldSync
access-list NoNat extended permit ip 192.168.0.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list NoNat extended permit ip 192.168.0.0 255.255.255.0 192.168.100.128 255.255.255.224
access-list NoNat extended permit ip 192.168.1.0 255.255.255.0 192.168.100.128 255.255.255.224
access-list NoNat extended permit ip any 192.168.0.128 255.255.255.224
access-list NoNat remark exempt main network NAT to P25Net1
access-list NoNat extended permit ip 192.168.0.0 255.255.255.0 P25Net1 255.255.255.0
access-list NoNat extended permit ip 192.168.0.0 255.255.255.0 P25Net3 255.255.255.0
access-list NoNat extended permit ip 192.168.0.0 255.255.255.0 P25NetAll 255.255.255.0
access-list remote_VPN_splitTunnelAcl standard permit any
access-list DefaultRAGroup_splitTunnelAcl standard permit any
access-list Split_Tunnel remark Allow inbound VPN Traffic to Forest network
access-list Split_Tunnel standard permit 192.168.0.0 255.255.255.0
access-list Split_Tunnel remark Allow inbound VPN Traffic to Blacksburg network
access-list Split_Tunnel standard permit 192.168.1.0 255.255.255.0
access-list outside_cryptomap_1 extended permit ip 192.168.0.0 255.255.255.0 192.168.1.0 255.255.255.0
pager lines 24
logging enable
logging asdm warnings
mtu inside 1492
mtu outside 1492
ip local pool ccti_pool 192.168.100.130-192.168.100.145 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp permit any outside
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list NoNat
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface 5993 192.168.0.30 5993 netmask 255.255.255.255
access-group 101 in interface outside
route outside 0.0.0.0 0.0.0.0 206.248.243.97 1
route inside P25NetAll 255.255.0.0 192.168.0.19 1
route inside P25NetAll 255.255.255.0 192.168.0.19 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server ccti_auth_server protocol radius
aaa-server ccti_auth_server (inside) host 192.168.0.30
timeout 5
key *****
nac-policy DfltGrpPolicy-nac-framework-create nac-framework
reval-period 36000
sq-period 300
http server enable
http 0.0.0.0 0.0.0.0 outside
http 0.0.0.0 0.0.0.0 inside
snmp-server host inside 192.168.0.111 community *****
no snmp-server location
no snmp-server contact
snmp-server community *****
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 1 match address outside_cryptomap_1
crypto map outside_map 1 set pfs
crypto map outside_map 1 set peer X.X.X.X
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto ca trustpoint LOCAL-CA-SERVER
keypair LOCAL-CA-SERVER
crl configure
crypto ca server
lifetime certificate 3650
crypto ca certificate map DefaultCertificateMap 10
crypto ca certificate chain LOCAL-CA-SERVER
certificate ca 01
     STUFF
  quit
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
vpn-addr-assign local reuse-delay 1
telnet timeout 5
ssh 192.168.0.5 255.255.255.255 inside
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.0.51-192.168.0.150 inside
dhcpd dns 192.168.0.30 X.X.X.X interface inside
dhcpd domain catcomtec2 interface inside
dhcpd update dns both override interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
enable outside
svc image disk0:/anyconnect-win-2.5.2014-k9.pkg 1
svc profiles AnnyConnectProfile disk0:/annyconnectprofile.xml
svc enable
certificate-group-map DefaultCertificateMap 10 AnyConnectRemote
group-policy cctivpn internal
group-policy cctivpn attributes
wins-server none
dns-server value 192.168.0.30 X.X.X.X
vpn-tunnel-protocol IPSec svc webvpn
split-tunnel-policy tunnelspecified
split-tunnel-network-list value Split_Tunnel
default-domain value STUFF
group-policy SSLUsers internal
group-policy SSLUsers attributes
wins-server none
vpn-tunnel-protocol svc webvpn
default-domain value catcomtec2
group-policy DefaultRAGroup internal
group-policy DefaultRAGroup attributes
vpn-tunnel-protocol l2tp-ipsec
split-tunnel-network-list value DefaultRAGroup_splitTunnelAcl
group-policy DfltGrpPolicy attributes
vpn-simultaneous-logins 10
nac-settings value DfltGrpPolicy-nac-framework-create
webvpn
  svc keepalive none
  svc dpd-interval client none
  svc dpd-interval gateway none
  svc compression deflate
group-policy remote_VPN internal
group-policy remote_VPN attributes
username ME password STUFF encrypted
username cisco password STUFF encrypted
tunnel-group DefaultRAGroup general-attributes
authentication-server-group (inside) ccti_auth_server
tunnel-group DefaultRAGroup ipsec-attributes
pre-shared-key *****
tunnel-group X.X.X.X type ipsec-l2l
tunnel-group X.X.X.X ipsec-attributes
tunnel-group cctivpn type remote-access
tunnel-group cctivpn general-attributes
address-pool ccti_pool
authentication-server-group ccti_auth_server
accounting-server-group ccti_auth_server
default-group-policy cctivpn
tunnel-group cctivpn ipsec-attributes
radius-sdi-xauth
tunnel-group AnyConnectRemote type remote-access
tunnel-group AnyConnectRemote general-attributes
authentication-server-group ccti_auth_server LOCAL
tunnel-group AnyConnectRemote webvpn-attributes
radius-reject-message
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
: end
[/code]
And the 2811
[code]
Username: admin
Password:
Username: admin
Password:
S6_bss1r1>en
Password:
S6_bss1r1#sh run
Building configuration...
Current configuration : 8965 bytes
! Last configuration change at 12:10:54 EDT Mon Nov 26 2012 by admin
! NVRAM config last updated at 12:10:57 EDT Mon Nov 26 2012 by admin
version 12.4
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname S6_bss1r1
boot-start-marker
boot-end-marker
logging buffered 64000
enable secret 5 STUFF
aaa new-model
aaa authentication login local_auth local
aaa session-id common
clock timezone EDT -5
dot11 syslog
no ip source-route
no ip gratuitous-arps
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.255.2.85 10.255.2.86
ip dhcp pool tech_pool
   network 10.255.2.80 255.255.255.248
   default-router 10.255.2.86
   domain-name STUFF
   lease 0 0 15
no ip bootp server
no ip domain lookup
voice-card 0
no dspfarm
key chain rt-auth-key
key 1
   key-string 7 STUFF
username admin secret 5 STUFF
archive
log config
  hidekeys
ip ftp source-interface Loopback0
class-map match-any ingress-radio
match access-group 100
match access-group 101
class-map match-any egress-audio
match ip dscp ef
policy-map setToS
class ingress-radio
  set ip dscp ef
policy-map GREIPSecToS
class egress-audio
  priority percent 75
class class-default
  fair-queue
interface Loopback0
description bss1r1v012_2009-06-24
ip address 10.255.3.1 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
interface FastEthernet0/0
description BSS2 Redundant Link
ip address 192.168.0.19 255.255.255.0
no ip redirects
no ip proxy-arp
no ip mroute-cache
duplex full
speed 100
no mop enabled
interface FastEthernet0/0.711
description WAN_To_bss1r2 Redundant
encapsulation dot1Q 711
ip address 10.255.3.213 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
interface FastEthernet0/1
description Trunk_to_WAS_or_r1s1u1sas
no ip address
duplex auto
speed auto
service-policy output GREIPSecToS
interface FastEthernet0/1.2
description Peripheral_VLAN
encapsulation dot1Q 2
ip address 10.255.2.78 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
interface FastEthernet0/1.5
description Technician_VLAN
encapsulation dot1Q 5
ip address 10.255.2.86 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
interface FastEthernet0/1.6
description Console_VLAN
encapsulation dot1Q 6
ip address 10.255.0.94 255.255.255.224
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
interface FastEthernet0/1.100
description Traffic
encapsulation dot1Q 100
ip address 10.255.0.62 255.255.255.192
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
service-policy input setToS
interface FastEthernet0/1.101
description Loghost
encapsulation dot1Q 101
ip address 10.255.1.62 255.255.255.192
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
interface FastEthernet0/1.106
description UAC_Interop
encapsulation dot1Q 106
ip address 10.255.1.158 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
interface FastEthernet0/1.150
description UAS_or_Cold_Stby
encapsulation dot1Q 150
ip address 10.255.2.254 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
interface FastEthernet0/1.200
description Backbone_Mgmt_VLAN
encapsulation dot1Q 200 native
ip address 10.255.2.110 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
interface FastEthernet0/1.300
description Management_VLAN
encapsulation dot1Q 300
ip address 10.255.2.62 255.255.255.192
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
interface FastEthernet0/1.701
description to_r1s1u1sas
encapsulation dot1Q 701
ip address 10.255.3.221 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
interface FastEthernet0/1.707
description to_r1s2u1sas
encapsulation dot1Q 707
ip address 10.255.3.173 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
interface FastEthernet0/1.708
description to_r1s3u1sas
encapsulation dot1Q 708
ip address 10.255.3.165 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
interface FastEthernet0/1.710
description to_BSS2
encapsulation dot1Q 710
ip address 10.255.3.229 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
interface FastEthernet0/1.713
encapsulation dot1Q 713
ip address 10.255.3.205 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
interface FastEthernet0/1.715
description to_r1s4u1sas
encapsulation dot1Q 715
ip address 10.255.3.197 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
interface FastEthernet0/1.717
description to_r1s5u1sas
encapsulation dot1Q 717
ip address 10.255.3.189 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
interface FastEthernet0/1.719
description to_r1s6u1sas
encapsulation dot1Q 719
ip address 10.255.3.181 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
router mobile
router eigrp 10
redistribute static metric 1536 200 255 1 512
redistribute mobile
passive-interface FastEthernet0/1.2
passive-interface FastEthernet0/1.5
passive-interface FastEthernet0/1.6
passive-interface FastEthernet0/1.100
passive-interface FastEthernet0/1.101
passive-interface FastEthernet0/1.106
passive-interface FastEthernet0/1.150
passive-interface FastEthernet0/1.200
passive-interface FastEthernet0/1.300
passive-interface Loopback0
network 10.0.0.0
no auto-summary
eigrp router-id 10.255.3.1
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.0.5
ip route 0.0.0.0 0.0.0.0 Null0 253 name Trash_Unknown_Traffic
no ip http server
no ip http secure-server
ip mobile home-agent address 10.255.3.1 lifetime 65535
ip mobile bindupdate maximum 2 retry 2
ip mobile bindupdate acknowledge
ip mobile virtual-network 10.255.16.0 255.255.248.0
ip access-list standard V1D@v!da
ip access-list standard vIdAr0R$
logging source-interface Loopback0
access-list 10 permit 10.255.0.0 0.0.15.255
access-list 15 permit 10.255.0.0 0.0.15.255 log
access-list 100 permit udp any any eq 11800
access-list 100 permit udp any eq 11800 any
access-list 100 permit udp any any eq 11200
access-list 100 permit udp any eq 11200 any
access-list 101 permit udp any any range 11801 12000
access-list 101 permit udp any range 11801 12000 any
access-list 150 permit ip any any
snmp-server community macom RO
snmp-server community vida RW
snmp-server trap-source Loopback0
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps envmon
snmp-server enable traps config
snmp-server enable traps ipmulticast
snmp-server host 10.255.0.10 macom
control-plane
line con 0
session-timeout 9
exec-timeout 5 0
logging synchronous
login authentication local_auth
history size 100
transport output telnet
line aux 0
no exec
transport preferred none
transport output none
line vty 0 4
session-timeout 30000
access-class 15 in
exec-timeout 5 0
logging synchronous
history size 100
transport preferred telnet
transport input telnet
transport output all
scheduler allocate 20000 1000
ntp source Loopback0
ntp master
end
S6_bss1r1#
[/code]
8 Replies 8
Richard Burts
Kenneth
Perhaps there are parts of your situation that I am not understanding. You say that your objective is:
Since the 1921.168.0.0 network is a directly connected network on the router Fast0/0 it should be the case that the devices connected to the router should communicate with 192.168.0.0 with no problem - and would not need the ASA for the communication to work.
Perhaps you can give us some clarification about the issue - perhaps some specifics of what communication you want to occur that does not occur. Is there a specific device connected to the router that can not communicate with some device in the 192.168.0.0 network?
Rick
Rick
Sure thing.  Basically what I need to make happen is that the developers on the 192.168.0.0/24 network need to be able to remotely access the equipment that is connected to the 2811 router.  The fe0/0 interface was given to us to attach to our network, while the fe0/1 (and all of its sub interfaces) are preconfigured with vlans that are attached to various devices.  We can ping 192.168.0.19 without issue, I just can't ping over to anything configured behind that 2811 router.
To test out my work, I have been using the ping command from the 2811 to source an IP on that router (10.255.3.213 for instance) to ping over to my inside interface on the ASA (192.168.0.5).  However, I have been unsuccessful in doing so.
I believe that I am missing something (a route for the vlans?  A NAT setting on the 2811?) to make this happen.
Ok, I narrowed things down a bit.
I modified my setup for testing like so:
laptop (192.168.0.18) --> switch --> 2811 Router
I can ping the 2811 router and the IP's on the interfaces on the vlans that are on this router, so this router is fine.  What appears to be the problem is the ASA is not letting me pass traffic to the router when I have a system connected to it.
I did a packet trace from the ASA itself:
Result of the command: "packet-tracer input inside rawip 192.168.0.5 0 10.255.3.1 detailed"
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
Forward Flow based lookup yields rule:
in  id=0xc9599d40, priority=1, domain=permit, deny=false
    hits=478993860, user_data=0x0, cs_id=0x0, l3_type=0x8
    src mac=0000.0000.0000, mask=0000.0000.0000
    dst mac=0000.0000.0000, mask=0100.0000.0000
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   P25NetAll       255.255.0.0     inside
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
in  id=0xc95355d0, priority=500, domain=permit, deny=true
    hits=4, user_data=0x6, cs_id=0x0, reverse, flags=0x0, protocol=0
    src ip=192.168.0.5, mask=255.255.255.255, port=0
    dst ip=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
However, I have this line in my access-list:
access-list NoNat line 5 extended permit ip 192.168.0.0 255.255.255.0 P25NetAll 255.255.0.0 (hitcnt=0) 0x4f45d901
Where P25NetAll is covering the 10.255.0.0, 10.255.1.0, 10.255.2.0, and 10.255.3.0 networks.
So what am I missing?
Here is a screenie of my ASA inside IPV4 incoming rules.  When I use the graphical packet tracer, I see that this is where the blocking is occuring.
However, if I try to add a rule that allows traffic to pass to the 2811, it replaces this first implicit rule.
Kenneth
The additional information that you posted is interesting. And I am glad that you are narrowing the focus to find the problem is the access list. I believe that the issue is that there are two entries in the access list. The first entry permits any  traffic that arrives on the inside interface and will be forwarded to a less secure interface. The second entry denies all other traffic.
I believe that part of the issue is that the traffic is received on the inside interface and will be forwarded back out the same interface. Since it is not to a less secure interface it is not permitted by the first entry and so is denied by the second entry.
One solution would be to insert a rule between those two rules that would permit traffic being forwarded back out the same interface.
I believe that there may be another alternative to consider and that it might be less complex to implement. It looks like the devices in the 192.168.0 network are configured with the ASA as their default gateway. I would suggest that you think about configuring them to use the 2811 as their default gateway. This would allow them to access the 10.255 networks without going through the ASA and would use the ASA as the next hop for any destination that was not in the 10.255 networks.
I also notice something in the output that puzzles me. I looked at the output in the section that has the access list deny. And I noticed something unexpected about what it lists as the destination address
I am not sure how to interpret this.
Rick
Rick
did you change the config from the original post before doing the packet-tracer?  I see the following in original config.
Do you have access to syslog debugging? Can you obtain the logs from a connection attempt?
Actually, a colleage suggested that I just create another vlan to tie that 2811 in to and leave it there (since supposedly the vlans would route between themselves).
So I set up another vlan (called P25) and set it up on interface 0/1 on the ASA:
interface Vlan3
no forward interface Vlan2
nameif P25
security-level 50
ip address 192.168.15.1 255.255.255.0
switchport access vlan 3
I changed the IP on the 2811 to 192.168.15.2, and then I then added a static route for the networks on the 2811:
route inside P25NetAll 255.255.0.0 192.168.15.2 1
I thought that would work, but I couldn't ping 192.168.15.1 from the 192.168.0.0 network.  Looking things up online, it was suggested that the intra interfaces were setup to allow traffic to pass through:
That still didn't work, so I had made sure that my access lists were ok:
access-list NoNat extended permit ip 192.168.0.0 255.255.255.0 P25NetAll 255.255.0.0
access-list NoNat extended permit ip 192.168.0.0 255.255.255.0 192.168.15.0 255.255.255.0
access-list NoNat extended permit ip 192.168.15.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list inside_access_in extended permit ip 192.168.0.0 255.255.255.0 any
access-list inside_access_in extended permit ip 192.168.1.0 255.255.255.0 any
access-list inside_access_in extended permit ip 192.168.100.128 255.255.255.224 any
access-list inside_access_in extended permit ip 192.168.20.0 255.255.255.0 any
access-list inside_access_in extended permit ip 192.168.3.0 255.255.255.0 any
access-list P25_access_in extended permit ip 192.168.0.0 255.255.255.0 192.168.15.0 255.255.255.0
access-list P25_access_in extended permit ip 192.168.1.0 255.255.255.0 192.168.15.0 255.255.255.0
access-list P25_access_in extended permit ip 192.168.3.0 255.255.255.0 192.168.15.0 255.255.255.0
That still didn't resolve it, then I found that I should make sure that there is no NAT'ting between the vlans:
static (inside,P25) 192.168.0.0 192.168.0.0 netmask 255.255.255.0
static (P25,inside) 192.168.15.0 192.168.15.0 netmask 255.255.255.0
And yet I'm still stuck.
@Richard Burts:  I tried your idea of making the 2811 the default gateway, and that does work.  However, I can't run with that in production since the ASA is also our VPN concentrator.  If I can't get the routing to work properly on the ASA to talk to this 2811, then the VPN guys won't be able to work through the 2811 either.
