suggest router for redundancy
Dear all,
I have two internet lease line connections from two different isp providers.one is of 6 mbps and another one is of 4 mbps.
i want to connect these both two lines to the router for redundancy purpose. please suggest me a best router.
Leo Laohoo
Hmmmm ... Depending on the number of VLANs you will have in your network, the 860 (1 VLAN), 880 and the 890 will fit the bill. For redundancy, I recommend that you get TWO routers in case one should fail.
Joseph W. Doherty
Disclaimer
The Author of this posting  offers the information contained within this posting without  consideration and with the reader's understanding that there's no   implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind.  Usage of  this posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever  (including,  without limitation, damages for loss of use, data or  profit) arising  out of the use or inability to use the posting's  information even if  Author has been advised of the possibility of such  damage.
Posting
Leo's suggestions  are good, although the 860 might be only be "just enough" even in dual router implementation.  880 should be fine in dual but perhaps a little tight for single router implementation.  (NB: BTW, Leo's suggestion would likely work just fine, personally I like a bit more reserve processing capacity.)  What bandwidth growth, if any, do you anticipate?
Since you did mention redundancy, Leo's suggestion for two routers is excellent.  However, if you don't already have it, also provide some LAN redundancy.  For example, you might have each of your WAN routers connect to two different switches or to different stacked switches.
