Etherchannel went down when one stackmember lost power
pd.politiet.no
Level 3
Level 3
Hi.
I have 2 3750 running IOS 12.2(35)SE5. Today I lost power to one switch in one of the stacks.
Since I've configured etherchannel, it should work fine.  But it didn't.  The switch in the opposite end, reported interface Gi1/0/1, Gi2/0/1 and Po1 down.  No further logging in neither of the switches.
Why didn't the etherchannel configuration keep the trunk up?
Have I missed something, is there a bug in the IOS release or why did this happen?
Logging inn to one of the switches, issuing shut no shut on the interfaces (int gi1/0/1 and int po1) makes the interfaces come up.
I'm searching google for answers, while I'm hoping one of you guys can help me.
Br
Geir
SWITCHSTACK1            SWITCHSTACK2
Switch1-1 gi1/0/1 <-----> gi1/0/1 Switch2-1
Switch1-2 gi2/0/1 <-----> gi2/0/1 Switch2-2
----------switch 2--------------------
switch1#sh run int gi1/0/1
interface GigabitEthernet1/0/1
switchport trunk native vlan 998
switchport trunk allowed vlan 456,800-849,998
switchport mode trunk
switchport nonegotiate
storm-control broadcast level 5.00
storm-control multicast level 10.00
channel-group 1 mode active
end
switch1#sh run int gi2/0/1
interface GigabitEthernet2/0/1
end
switch1#sh run int po1
interface Port-channel1
description Etherchannel mot Digiplex
end
switch1#
switch2#sh run int gi1/0/1
end
switch2#sh run int gi2/0/1
end
switch2#sh run int po1
end
ranraju
If are able to reproduce this issue, and if you see the same issue again every time a member switch power cycles in your enviroment, then it might be a buggy behavior and you might have to open a TAC case to investigate further.
ranraju
Leo Laohoo
Wow.  That's an old IOS.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no  implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind.  Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever  (including, without limitation, damages for loss of use, data or  profit) arising out of the use or inability to use the posting's  information even if Author has been advised of the possibility of such  damage.
Posting
Nothing looks wrong, but if you can reproduce the problem, you might try turning LACP off (i.e. use manual mode) and see if that makes a difference.
