Sup2T What is the function NVRAM Battery ??
hyunki9898
Hi. all
C6509E Sup2T. Major error.
The reason TestNVRAMBatteryMonitor ---------> F
Battery Fail.
InayathUlla Sharieff
         CSCub30570            Bug Details
6k: Sup2T TestNVRAMBatteryMonitor Failure
Symptom:
- Minor or Major failure in "show mod" under SUP2.
- TestNVRAMBatteryMonitor failure count increment via "show diagnostic result mod < x> test < x> detail
- OBFL logg message from "show logging onboard"
GOLD_OBFL-3-GOLD : Diagnostic OBFL: Low NVRAM battery power is detected on module < x>
- Syslog message from "show logging"
CONST_DIAG-2-LOW_NVRAM_BATTERY_FOR_THREE_DAYS: Low NVRAM battery power detected for 3 consecutive days on module < x>
Majority  reported problem have been corrected by removing the SUP, pressing the  battery, and insert the SUP again. If this procedure does not resolve  the issue, please open TAC case.
Conditions:
This bug only applies to SUP2T only.
Inayath
*Plz rate all usefull posts.
Symptom:
Conditions:
Inayath
