Regarding VLAN trunk
ncnaveen_arasu
i team,
What is the effect of the below comand when we configure under swith interface and the same interface if connected to switch or Router.
switchport access vlan 601
switchport mode trunk
Please explain.
Thanks in advance.
Naveen
InayathUlla Sharieff
Naveen,
If the other side of this port is configured as trunk port then the port would be negotiated as trunk port hence there wouldnt be any use of access vlan 601 on the trunk port.
The command "switchport access vlan 601" has no effect in the second configuration since the switch ports are in trunking mode.
INayath
**Plz rate all usefull posts.
Let me give you a basic example:
I have connected 2 switches;
Switch 1-----F0/1--------------------F0/1---Switch 2
config
Switch 1
interface FastEthernet0/1
switchport access vlan 20
Switch 2
Result:
Trunk negotiated and its passing all the vlans traffic over the trunk ports.
Switch-1
Switch1#sh int trunk
Port        Mode         Encapsulation  Status        Native vlan
Fa0/1       on           802.1q         trunking      1
Port        Vlans allowed on trunk
Fa0/1       1-1005
Port        Vlans allowed and active in management domain
Fa0/1       1,10,20,30,40,50
Port        Vlans in spanning tree forwarding state and not pruned
SWitch2#sh int tr
Fa0/1       1-1005
Inayath
*PLz rate and mark the thread as answwered if it answered your query.
Hi shareiff,
Thanks for the reply.
If we connect the router fast ethernet  at other end, what will be the possibility of the above mentioned command when we use router on stick concept.
