Sup720-3BXL stuck on SP
joe.fodor
     I have a SUP720-3BXL that will not boot. It will get stuck at booting from the SP. It never switches over to the RP.
this is where it stops booting at
"rommon 4 > boot disk0:s72033-adventerprisek9_wan-mz.122-33.SXI9.bin
Loading image, please wait ...
Initializing ATA monitor library...
Self extracting the image... [OK]
Self decompressing the image : ####################################################################################################################################################################################################### [OK]
HW indicate it is sup3, but idprom is not"
Is the SP bad?
Thank you in advance.
7 Replies 7
Reza Sharifi
When you are in rommon mode,
what is the outout of:
dir bootflash:
rommon 3 > dir bootflash:
Directory of bootflash:
2      118701412 -rw-     s72033-adventerprisek9_wan-mz.122-33.SXI9.bin
Can you try
confreg 0x2102
Also, since you have the IOS in bootflash:
Can you try booting from boot flash instead of disk0:
boot bootdisk:s72033-adventerprisek9_wan-mz.122-33.SXI9.bin
Yeah nothing is working I think I am going to RMA this card thanks for the help though
Yes, if it is under Warranty and you have SmartNet open a ticket with TAC and RMA it.
tconner01
I had the same issue, the causes could be different but I solved it by going into rommon after it switched over to the route processor, then I went into confreg and discovered the boot characteristics were not set to what they should have been. I changed the setting to 2 and once I reset I started getting clean boot ups.
I have this problem too. Try to upgrade ROMMON it's work for me.
http://ccie-in-3-months.blogspot.com/2008/06/upgrading-rommons-in-6500s7600s-with.html
