03-04-2009 03:13 AM - edited 03-06-2019 04:22 AM
Supervisor engine 720 redundancy takeover failure
Here is the configuration,
1x 6513
1x WS-C6K-13slot
2x ws-sup720-3b
2x ws-cdc-2500W
2x ws-x6516a-gbic
2x ws-x6548-rj-45
OS image :
The sups are in redundancy mode. They are both running the following image:
S72033-pk9sv-mz.122-17d.sxb11.bin
Issue :
The redundant sup did not pick up properly
Indicates that the" boot file did not load, it stayed in ROM monitor"
1)Why did the supervisor engine fail?
2) why didn't the redundant supervisor engine pickup when the active one failed?
Please help me out to fix this issue. Its critical. Thanks in advance
03-04-2009 01:29 PM
Thanks again.
I am trying to check if that happens again.
How can i get the crashfile to you?
03-04-2009 03:12 PM
Can you please tel me, how i can get the crushfile from the sup720
03-04-2009 03:58 PM
Mark,
How i can get you the crashfile, is that by trasfer upload /path?
03-04-2009 06:43 PM
If you have a PC running a TFTP server ( I personally use and recommend tftpd32). You will want to copy the crashfile using tftp.
copy bootflash:crashfilename tftp
Address or name of remote host []? 10.10.1.100 (replace IP with your PC IP address)
Destination filename [crashfilename]?
10035 bytes copied in 0.068 secs (147574 bytes/sec)
Note: Make sure the crashfile name is correct. Verify this by issuing the show bootflash: command.
Then add the crashfile as an attachment on the forum.
HTH,
Mark
03-05-2009 05:55 AM
Thanks Mark, i will get the crashfile today
03-05-2009 08:06 AM
I am working on the ssh, and the tftp server not configured at the remote end.
how i can get you the details ?
03-05-2009 08:08 AM
copy crashinfo_20090301-110626 tftpd32
03-05-2009 08:09 AM
The above command copied the information, how i can get the file?
03-05-2009 09:55 AM
