supervisor engine EOL
ashfaqmd
Community Member
Please help me to buy the supervisor engine of 6509 core switch and supervisor engine model no is vs-s2t-10g-2.
can you please help me to choose the supervisor engine .
BTW who told you that this is EOL/EOS?
Cisco has NOT YET made any moves to replace Sup2T.  Development for the Sup3T is still in progress (Sup10T is put on hold).
Inayath
*Please rate the usefull posts.
6 Replies 6
InayathUlla Sharieff
Please find the details on the below link:-
6500 Catalyst models:-
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/hardware/Module_Installation/Sup_Eng_Guide/supe_gd/01overvw.html
Sup modules:-
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/hardware/Module_Installation/Sup_Eng_Guide/supe_gd/02superv.html
NOTE:- vs-s2t-10g supported only in Catalyst 6500 E-series switches.
Thanks for your quick reply
vs-s2t-10g is EOL
Please help me
Please find below info:-
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-series-switches/eos-eol-notice-c51-734057.html
Product Part Numbers Affected by This Announcement
End-of-Sale Product Part Number
Product Description
Replacement Product Part Number
Replacement Product Description
Additional Information
VS-C6506E-S2T-6816
Catalyst Chassis+Fan Tray+ Sup2T+2x6816; IP Services ONLY
VS-C6506E-SUP2T
Catalyst Chassis+Fan Tray + Sup2T; IP Services ONLY incl VSS
VS-C6506E-S2T-6904
Catalyst Chassis+Fan Tray+ Sup2T+2x6904; IP Services ONLY
VS-C6506E-SUP2T
VS-C6509E-S2T-6816
VS-C6509E-SUP2T
VS-C6509E-S2T-6904
VS-C6509E-SUP2T
Inayath
Thanks for your response
