Supervisor Engine II-Plus and WS-X4612-SFP-E compatibility
mesumbeslin
Hi all,
I recently bought a
WS-X4612-SFP-E line card to increase our fiber port density on a 4506-E switch but it fails to show in inventory nor do the status led come on. We use Supervisor engine II-plus, I was wondering if this engine supports the card since I couldn't find any doc that shows which line cards the sup II-plus suports
Output of sh version:
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-IPBASE-M), Version
12.2(50)SG3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Tue 07-Jul-09 19:16 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x11AA6AB0
ROM: 12.2(31r)SGA2
Dagobah Revision 226, Swamp Revision 34
CORE_SWITCH uptime is 38 minutes
System image file is "bootflash:cat4500-ipbase-mz.122-50.SG3.bin"
cisco WS-C4506-E (MPC8245) processor (revision 10) with 262144K bytes of memory.
Processor board ID FOX1346GVT4
MPC8245 CPU at 266Mhz, Supervisor II+
Last reset from PowerUp
19 Virtual Ethernet interfaces
56 Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Any leads will be helpfull.
Tomslin
Aninda Chatterjee
I do not think that this card is compatible with the supervisor engine that you are running. The card in question only runs with a Sup6E, a Sup6L-E or a Sup7E.
Please see below:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/hardware/configuration/notes/OL_25315.html
Aninda
Aninda Chatterjee
Please see below:
Aninda
