IOS upgrade from 12.4(15)T15 to 15.2(4)M4 for 7206 vxr with NPE-G2
WIN PHYO AUNG
1.  I would like to check that  our router , 7200 series , is now running Version 12.4(15)T15, SP Services. If we upgrade to 15.2(4)M4,SP Services,  will there be any license required on that new IOS or it will works with the default?
We are running  “tracking using IP SLA, OSPF, Redistribution static routes using prefix list, QOS with MQC ” on the router.
2. If we upgrade to 15.2(4)M4,SP Services, any issue with bootstrap version and do we need to upgrade system bootstrap ?
Cisco IOS Software, 7200 Software (C7200P-SPSERVICESK9-M), Version 12.4(15)T15, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 08-Mar-11 10:52 by prod_rel_team
ROM: System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200P-BOOT-M), Version 12.4(15)T15, RELEASE SOFTWARE (fc3)
RT1_DC1_1A uptime is 1 year, 43 weeks, 2 days, 3 hours, 58 minutes
System restarted at 13:18:24 SGT Fri Oct 7 2011
System image file is "disk2:c7200p-spservicesk9-mz.124-15.T15.bin"
Cisco 7206VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memory.
Processor board ID 37108246
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.2
6 slot VXR midplane, Version 2.11
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 0 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
1 FastEthernet interface
3 Gigabit Ethernet interfaces
2045K bytes of NVRAM.
253008K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 512K).
sh inv :
NAME: "Chassis", DESCR: "Cisco 7206VXR, 6-slot chassis"
PID: CISCO7206VXR      , VID:    , SN: 37108246
NAME: "NPE-G2 0", DESCR: "Cisco 7200 Series Network Processing Engine NPE-G2"
PID: NPE-G2            , VID: V03 , SN: JAF1526BTTD
NAME: "disk2", DESCR: "256MB Compact Flash Disk for NPE-G2"
PID: MEM-NPE-G2-FLD256 , VID:    , SN:
Thanks in advnace.
Reza Sharifi
I don't think you need license for the 7200 series since they are EOS as of September 2012...
You just have to read the release notes to make sure all the features you need are supported in ios 15.
The final Cisco IOS Software Release supported on Cisco 7200 Series Routers is 15.2(4)M and 15.2(4)S.
See link:
http://www.cisco.com/en/US/prod/collateral/routers/ps341/end_of_life_c51-681414.html
