supervisor engine reload in 4500x series
Ashwin Jingade
In our infrastructure we are using 4500x series switch, its configured with VSS Cluster.
Since last week supervisor engine got rebooted 3 times.
Can some one help me to fix this issue ?
Logs:
%VSLP-5-RRP_ROLE_RESOLVED: Role resolved as ACTIVE  by VSLP
%EC-5-BUNDLE: Interface TenGigabitEthernet2/1/1 joined port-channel Port-channel20
%EC-5-BUNDLE: Interface TenGigabitEthernet2/1/2 joined port-channel Port-channel20
%C4K_REDUNDANCY-6-DUPLEX_MODE: The peer Supervisor has been detected
%SW_LEVEL-6-RESULT: Operational redundancy mode is UNKNOWN, due to software license-level mismatch at ACTIVE and STANDBY. Software Level on Active: ipbase; on Standby: ipbase.
%C4K_REDUNDANCY-6-MODE: ACTIVE supervisor initializing for sso mode
#sh ver :
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.04.03.SG RELEASE SOFTWARE (fc3)
 uptime is 1 year, 38 weeks, 6 days, 17 hours, 25 minutes
Uptime for this control processor is 1 day, 1 hour, 35 minutes
 sh sw vir
Executing the command on VSS member switch role = VSS Active, id = 2
Switch mode                  : Virtual Switch
Virtual switch domain number : 100
Local switch number          : 2
Local switch operational role: Virtual Switch Active
Peer switch number           : 1
Peer switch operational role : Virtual Switch Standby
Executing the command on VSS member switch role = VSS Standby, id = 1
Local switch number          : 1
Local switch operational role: Virtual Switch Standby
Peer switch number           : 2
Peer switch operational role : Virtual Switch Active
Hi Ashwin,
To check the license level on the standby login to standby sup using below
remote login module <standby module number>. You can get the module number using sh mod switch all or sh mod all (dont remeber exact syntax)
Then execute
sh ver
it will show the details of the installed license.
Hope this helps.
Madhu
10 Replies 10
Mark Malone
hey looks like a license issue
can you check what both sups have in each switch when there active , if there different sups wont sync to vss
I am trying to get the details in virtual switch but I am not getting in to the virtual switch.
How do I get in to 2nd switch to check these details
Note: These switches are located in different location I have a access via remote.
 If we have any command kindly share the same.
Switch : 1
sh license image levels
Module name        Image level  Priority  Configured  Valid license
WS-C4500X-32       entservices  1         NO          entservices
                   ipbase       2         NO          ipbase
Module Name     Role           Current Level     Reboot Level
WS-C4500X-32    Active         ipbase            ipbase
I only have 6500 vss so syntax is slightly different
I have a show license details standby
Is there northing with standby at the end for the secondary switch ? Are they too far away to go connect a console in
I have asked for console access to local support may be I am getting the same by tomorrow. As soon I get I will post the result.
It only support "#sh license detail"
sh license detail ?
  |  Output modifiers
  <cr>
output:
Index:  1       Feature: entservices  Version: 1.0
    License Type: Evaluation
      Evaluation total period: 8 weeks 4 days
      Evaluation period left: 8 weeks 4 days
    License State: Active, Not in Use, EULA not accepted
    License Count: Non-Counted
    License Priority: None
    Store Index: 0
    Store Name: Dynamic Evaluation License Storage
Index:  2       Feature: entservices  Version: 1.0
    License Type: PermanentRightToUse
    License State: Inactive
    Store Index: 1
Index:  3       Feature: ipbase  Version: 1.0
    License State: Active, In Use
    License Priority: Medium
    Store Index: 0
    Store Name: Primary License Storage
Index:  4       Feature: ipbase  Version: 1.0
    Store Index: 2
Index:  5       Feature: ipbase  Version: 1.0
    Store Index: 3
Hi Ashwin,
Then execute
sh ver
Hope this helps.
Madhu
Hi Mark
Both switches are having same image level and Sups module no changes.
I just saw the CISCO bug ID: CSCul23311
But no solution
Switch logs:
Switch 1:
sh lic ima lev
                   ipbase       2         NO          ipbase
Switch 2:
sh lic ima level
                   ipbase       2         NO          ipbase
That bug looks cosmetic, and i am not expecting the crash in your case is due to license mismatch either. Could you please check for crash dump ? Check it in standby bootflash or check the below command
sh platform crashdump (command may not be exact). You may need to remote loggin to standby module as well and check for same command.
If you can't find any crashfiles, I would recommend to RMA the standby sup since it reloaded 3 times in a week to rule out hardware issues as well.
Hope this helps.
Madhu.
Hello Madhu
No I didn't find any crash dump issue in both switches.
Even I am discussing with my next level to working cisco TAC.
Hope its a hardware issue and it get resolved with the help of CISCO TAC.
If you have any suggestion apart from this let me know.
Output:
Sw1:
Last Power Failure: 10/07/2014 12:30:24
No crash data available.
sh bootflash
-#- --length-- ---------date/time--------- path
  1       8323 May 07 2014 11:57:29 +00:00 startup-config.converted_vs-20140507-115721
  2  125611132 May 07 2014 11:11:07 +00:00 cat4500e-universalk9.SPA.03.04.03.SG.151-2.SG3.bin
  3       8323 May 07 2014 12:09:57 +00:00 startup-config.saved_vs-20140507-120957
1449472000 bytes available (125886464 bytes used)
Sw2:
Last Power Failure: 06/02/2014 17:06:40
sh bootflash
  1      11239 May 09 2014 08:42:03 +00:00 startup-config.saved_vs-20140509-084203
  2  125611132 May 07 2014 10:49:56 +00:00 cat4500e-universalk9.SPA.03.04.03.SG.151-2.SG3.bin
  3      23631 May 15 2014 13:08:29 +00:00 startup-config.saved_vs-20140515-130829
1449451520 bytes available (125906944 bytes used)
what doe the show version show in the section where power on does be ion the 4500 that rebooted does it show traceback or anything unusual other than power-on
Were there any other logs collected from syslog or anything before these  reboots
In both switches it shows only : "System returned to ROM by reload"
Logs
Sw1:
#sh ver
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-        UNIVERSALK9-M), Version 03.04.03.SG RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 19-Dec-13 14:08 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2010, 2012 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 15.0(1r)SG10
R-ES-ZA-011 uptime is 1 year, 39 weeks, 19 hours, 6 minutes
Uptime for this control processor is 2 days, 3 hours, 16 minutes
System returned to ROM by SSO Switchover
System restarted at 08:08:52 CET Mon Feb 29 2016
Running default software
SW2:
sh ver
software.
ROM: 15.0(1r)SG10
R-ES-ZA-011 uptime is 1 year, 39 weeks, 19 hours, 8 minutes
Uptime for this control processor is 2 days, 2 hours, 55 minutes
System restarted at 08:31:29 CET Mon Feb 29 2016
