IP Flow-export command not support on Cisco 3750G switch
Dhiraj Jagdale
I want to monitor incoming and outgoing traffic in Cisco 3750G switch but commands like IP flow-export and ip route-cache flow are not support in this switch model.
is there any other commands which is useful for monitoring the traffic ???
Mark Malone
Hey ye 3750s only support netflow in x series , they need a specific module too , standard 3750s don't support it as you seen
only other available commands I can think of may be ip accounting , or RITE if available on your ios version depending on what it is , you can span or rspan the ports either to wirehshark and just set the captures to be an hour long each that way if you something's happens at a specific time you can check the individual pcap based on the time.
there not ideal options but without netflow your limited
Mark Malone
Sunil Bhadauria
Hello Dhiraj ,
Platforms 3750-X and 3560x supports flexible netflow (FnF) however i think it is not supported for 3750G
You could try below guide for the configuration in case 3750X :
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/15-0_1_se/configuration/guide/3750xcg/swmnetflow.html
Sunil Bhadauria
