Suspect issue with OSPF
sharone.job
Dear Friendz,
     Connectivity: Telecom Equipment(TE)----RouterA----RouterB.
Pinging from RouA to TE worksbut trace route fails stating "% Subnet not in table".
IP address of TE in defined in OSPF table of RouterA.
Which all points to be checked? Please help...
jimmysands73_2
Level 5
Level 5
Is the route in the routeing table?
Amd do you see the route when using this command:
show ip ospf database
6 Replies 6
jimmysands73_2
Level 5
Level 5
Hi Sharone,
Is the neighborship established between TE and RouterA?
Can you make sure the TE network specified under OSPF?
Please rate the helpfull posts.
Naidu.
How can a ping work if the subnet you are trying to reach is not in the routing table ?
Are you tracerouting to a remote subnet beyond TE ?
Regards.
Alain
Thank you friends,
     Earlier i checked in the sh run and the IP was there under
router ospf 1
log-adjacency-changes
But in show ip ospf database the IP is not there..
@Alain: Ping worked.. because there is a default route there and it took another path, that i havnt mentioned earlier and sorry for confusing..
Thanks all for the help.
Problem not yet solved !
But IP Route is Created and re-distribution done,
router ospf 1
redistribute static subnets route-map RNC
Still its not working, please help...
post your config along with sh ip ospf database and sh ip route.
Regards.
Alain
