SVI issues
Eduardo Corzo
Community Member
Hello friends, I recently have a issue with my cisco equipments.
I have two 6500 and access switches which were configurated with ip from subnet 192.168.96.0/24, the configuration is almost like this:
CORE
int vlan 96
     ip add 192.168.96.1 255.255.255.0
     ip add 192.168.96.3 255.255.255.0 secondary
ACCESS SWITCH
int vlan 96
     ip add 192.168.96.30 255.255.255.0
ip default-gateway 192.168.96.1
The thing is, when I try to ping 192.168.96.1 doesn't work, but, when I change the default gateway for the secondary IP (192.168.96.3) it works perfect. There's a way that my primary ip (192.168.96.1) has been broken?
Thanks for the answers!
10 Replies 10
Reza Sharifi
Why do you have a secondary IP address on the SVI all the same subnet?
You usually need one IP for the SVI.
try removing the secondary IP and test again
config t
int vlan 96
no ip add 192.168.96.3 255.255.255.0 secondary
I just remove and put another ip in another subnet:
int vlan 96
ip add 192.168.97.1 255.255.255.0 secondary
but doesn't still work, it seems like the primary ip was broken, I can't ping to my default gateway 192.168.96.1 but, instead, I can ping to 192.168.97.1 and others devices using the vlan 96
Thanks for your help
Can you try the ping without having an ip secondary at all?
just delete the secondary completly and test with ping to 192.168.96.1
I would also suggest using show arp on the switch and check to see if there is an entry for 192.168.96.1. And if there is an entry check the MAC address in the entry and see if it match the MAC address of the switch interface.
Rick
Rick
Can you post the output to this command:  sh vlan | include 96?
Maybe VLAN 96 isn't created in the VLAN Database?
E31qinhaijun
Community Member
Hi,I have done this experiment. Such as:
R1#show run
Building configuration...
Current configuration : 1441 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip domain name lab.local
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/0
switchport mode trunk
interface FastEthernet1/1
interface FastEthernet1/2
interface FastEthernet1/3
interface FastEthernet1/4
interface FastEthernet1/5
interface FastEthernet1/6
interface FastEthernet1/7
interface FastEthernet1/8
interface FastEthernet1/9
interface FastEthernet1/10
interface FastEthernet1/11
interface FastEthernet1/12
interface FastEthernet1/13
interface FastEthernet1/14
interface FastEthernet1/15
interface Vlan1
no ip address
interface Vlan96
ip address 192.168.96.3 255.255.255.0 secondary
ip address 192.168.96.1 255.255.255.0
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
R2#show run
Current configuration : 1518 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip routing
no ip cef
no ip domain lookup
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
no ip route-cache
interface Vlan96
ip address 192.168.96.30 255.255.255.0
no ip route-cache
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
The results are as follows:
R2#ping 192.168.96.1
Sending 5, 100-byte ICMP Echos to 192.168.96.1, timeout is 2 seconds:
R2#ping 192.168.96.3
Sending 5, 100-byte ICMP Echos to 192.168.96.3, timeout is 2 seconds:
I hope this can help you
Hello
Is the connection between the 6500 and access switch trunked?
Both switches:
interface xxx
ACCESS SWITCH
no ip routing
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
Eduardo Corzo
Community Member
Hello everyone,
Thanks a lot for your help! all the configuration that Haijun shows is almost the same I have, with trunkings and everything needed up. The vlan 96 was created like a month ago, everything was working but someone change the ip add twice, like this:
CORE
int vlan 96
ip add 192.168.96.40 255.255.255.0
exit
int vlan 96
exit
wr
After that change, the switches starts with the issue, I can't ping my switches from the CORE but my switches can ping to 192.168.96.1. In the arp table of one access switch I saw a entry like 192.168.96.1 Incomplete.
I'd like to know if someone had the same issue or almost something like that.
Again, thanks to lot for all your answers, it's very helpful for my troubleshooting
Hello
Are you still experiencing this issue?
If so can you post the running config of the access switch?
res
Paul
Thanks.
Kind Regards
Paul
Eduardo Corzo
Community Member
Hello friends,
I just discover that the problem was realted with spanning-tree, all was about the root guard configured on the Core, it blocked the vlan96, so I need to configured the Core in order to make the vlan96 as the root bridge.
Thanks again for all you answers!
