SW Forwarding - Drops
Hi all,
hope you can help me understand this. I searched on the forum but couldn't find exactly the answer to what this could mean
When doing the command "show controllers cpu", I get the following on the sw forwarding:
                     retrieved       dropped      invalid      hol-block
sw forwarding 53865           7846             0              0
All the interfaces have 0 drops and the cpu is at 3% utilization
What does the fw forwarding means? Should I worry about those drops?
Thank you
Reza Sharifi
What platform do you use and what is the issue you are trying to resolve?
Sorry forgot to say it's a Cisco 3650, the issue itself is none, I'm just monitoring the switch and saw those drops on the CPU controllers, but don't know if I should worry to be honest, my biggest issue is I don't know what the sw forwarding does and means
Thank you Reza
