swicth 3750, stack problem
giovanni.cock
Level 3
Level 3
we removed a switch 3750 from its stack, after that, the switch boots well like a standalone switch, but it gets soo slowly for example when i want to see its configuration through the console port (sh run), i review the sh switch, and i am still seeing that these switch are using the same id member that it used when it was in the stack, how can solve this? why the switch takes the number 2, and not the one? if i see the ports, the numbers begin by 2/0/1, and not by 1/0/0, could this problem cause the slow of the switch? this switch was the switch number 2 when it was in the stack. i cleared its configuration, and the i restarted, but the same.
Switch#sh switch
Switch/Stack Mac Address : 0023.ea09.0323
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*2       Master 0023.ea09.0323     1      0       Ready
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
no aaa new-model
switch 2 provision ws-c3750g-48ts
system mtu routing 1500
ip subnet-zero
vlan internal allocation policy ascending
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
giovanni.cock
Level 3
Level 3
i have tryied with two different images, they are:
-c3750-i5-mz.122-20.SE4.bin
-c3750-ipbase-mz.122-35.SE5
the same behavior.
thanks
Reza Sharifi
Hello Giovanni
Try removing "switch 2 provision ws-c3750g-48ts" from your config
no switch stack-member-number provision
And test again.
Reza
do a config t
switch 2 renumber 1
Enter
and reboot.
Unfortunately, you will have to reconfigure the thing.  Copy your config to a wordpad and then replace all 2/0/x with 1/0/x and paste it in.
Should work fine.
James
