Showing results forĀ
Search instead forĀ
Did you mean:Ā
Switch 2 does not have sufficient power budget after upgarde
Paul Freiberg
Hallo Community,
we upgarded a stack of two 3750X-48T-S from 122-53.SE2 to 15.0(2)SE5. Now we got every minute this error:
Dec 16 10:39:21: %PLATFORM_STACKPOWER-4-UNDER_BUDGET: Switch 2 does not have sufficient power budget
We restartet the  stack, we unpluged the power cable one by one and changed stack-power mode from Power sharing to Power sharing strict without success.
Power Stack           Stack   Stack    Total   Rsvd    Alloc   Unused  Num  Num
Name                  Mode    Topolgy  Pwr(W)  Pwr(W)  Pwr(W)  Pwr(W)  SW   PS
Powerstack-1          SP-PSS  Ring     700     271     446     -17     2    2
Power stack name: Powerstack-1
    Stack mode: Power sharing strict
    Stack topology: Ring
    Switch 1:
        Power budget: 223
        Power allocated: 223
        Low port priority value: 21
        High port priority value: 12
        Switch priority value: 3
        Port 1 status: Connected
        Port 2 status: Connected
        Neighbor on port 1: Switch 2 - c471.fe52.1500
        Neighbor on port 2: Switch 2 - c471.fe52.1500
    Switch 2:
        Power budget: 206
        Low port priority value: 22
        High port priority value: 13
        Switch priority value: 4
        Neighbor on port 1: Switch 1 - 588d.09d0.0080
        Neighbor on port 2: Switch 1 - 588d.09d0.0080
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1A  C3KX-PWR-350WAC     LIT14410708 OK              Good     Good     350/0
1B  Not Present
2A  C3KX-PWR-350WAC     LIT1441070H OK              Good     Good     350/0
2B  Not Present
Can someone help?
Paul
Leo Laohoo
Downgrade your IOS to 15.0(2)SE4 and see if the error message goes away.
For the record, 15.0(2)SE4 is not a good IOS to be using.
