Switch 2960 POE power failure cannot start
Do Tien Dung
I have unplugged and rebooted but still can't seem to boot up
I use Console to loggin this device but It doesn't work
Model : WS-C2960-24PC-L
Switch Version: 12.2(44)SE3
Image : C2960-LANBASE-US
SN: FOC1241Z0XK
This device
End of Sale 2014-10-31
End of Support 2019-10-31
Can I RMA and change to another device
Thanks & Best Regards,
Do Tien Dung
Technical staff - Service support department
IT Operations Center
57 Huynh Thuc Khang Street, Dong Da District,
Ha Noi Capital, Viet Nam
www.vnptit.vn
live:.cid.edce5e4917b06b34
Hello
 If you can RMA, go for it. But, you provided a lot of information, most of them not necessary here and you did not provide any log or usefull information.
When you say your console to it but doesn´t work what do you mean? The console does not show you any information? Are you using the proper cable, PC adapter etc? Can you use this same console cable in another device?
The equipment of my company has changed the power supply for the entire system, the switches are suddenly turned off
Some of them are still running fine, but this device won't boot up
Do Tien Dung
www.vnptit.vn
I have correctly set the baud rate to 9600 but can't access the device
Do Tien Dung
www.vnptit.vn
