Switch 2960
Waheed Bahaduri
I am ordering cisco 2960 series.  I need the following features only.  please recommend which IOS i should order with it.  LAN_Base or LAN_Lite ?
Features  I need >>
802.1X
VLAN Management Interface support
Robenneke
Level 2
Level 2
Take a look here:
http://tools.cisco.com/ITDIT/CFN/jsp/by-feature-technology.jsp
Kind regards
LAN Lite is always very limited in terms of features and doesn't give you much more then basic switching. For 802.1X you find the available features in the config-Guide:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-2_2_e/security/configuration_guide/b_sec_1522e_2960x_cg/b_sec_1522e_2960x_cg_chapter_010.html
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Thanks Karsten
