switch 2960S username problem
mohamed sebaey
After i have already configured my cisco switch 2960 , i configured my console as the below
line con0
password xx
login
exit
after i reboot my switch , i found that the switch asked me for username . However i did not configure username , how can i solve this problem , without password reset . I have already configured 15 switch , 100% this problem will be in all switches.
thank you
19 Replies 19
Thanks you so much , i apperciated for your help.Again to get my problem so clear , I have Cisco switch 2960S and configured under console a password with login after i reboot the switch , i found that switch asked me about username and password. I tried other switch without put a password under console , and reboot switch all things are fine. Waiting for your help. I didnot configure any username
thanks
In this case please post sh version to clarify IOS and switch version.
So you are saying that other switches are fine just this one switch has an issue?  Why don't you just reset it?
Hello
You may need to perform a password recovery
http://www.cisco.com/en/US/products/hw/switches/ps628/products_password_recovery09186a0080094184.shtml
Res
Paul
Kind Regards
Paul
The switches which have the problem aout 15 switches , it will be a long time to reset 15 switches.
