switch 4500x vss telnet access issue
i have 2 switches 4500x with VSS and i can access with telnet and console
but once i cant access telnet and console and appear password required, but not set
Reza Sharifi
Make sure you have "login local" enabled under the vty lines.
also, make sure you have set the username and password
example:
username cisco password cisco
username cisco privilege 15
all telnet configuration was exist and after 6 month VSS configuration telnet configuration deleted
shouldn't be using telnet its insecure you can see passwords on a wireshark , use SSH
what happened for it to be deleted ,. was the device rebooted , config not saved ?
we cant tell from the information thats been provided so far , is there any logs form the day the issue occurred ?
