switch allowed 2 vlan
LCMC
I have a Switch 3560/24 ports
i want know, how can i allow two vlans in a one switchport?
Vlan voice and vlan data.
Luis Coiro
cadet alain
int f0/0
switchport mode access
switchport access vlan 10     <<<<< data vlan
switchport voice vlan 20        <<<<<< voice vlan
Alain
Hi, alain.
I try, but the switchport continiuos in one vlan
SWFISA11-1(config)#interface fastEthernet 0/1
SWFISA11-1(config-if)#switchport mode access
SWFISA11-1(config-if)#switchport access vlan 220   <<<< data vlan
SWFISA11-1(config-if)#switchport access vlan 200   <<<<< voice vlan
SWFISA11-1#show vlan brief
VLAN Name                             Status    Ports
1    default                          active    Gig0/1, Gig0/2
30   VLAN0030                   active    Fa0/5, Fa0/21
128  MedicaSur                  active
200  VLAN0200                  active    Fa0/1, Fa0/6, Fa0/7, Fa0/8
                                                         Fa0/9, Fa0/10, Fa0/12
210  VLAN0210                  active    Fa0/2, Fa0/11, Fa0/13, Fa0/16
                                                        Fa0/17, Fa0/18, Fa0/19, Fa0/20
220  VLAN0220                 active    Fa0/15
1002 fddi-default                     active
1003 token-ring-default               active
1004 fddinet-default                  active
1005 trnet-default                    active
I try, but the switchport continue in one vlan.
Maybe the configuration of the vlan??  need configuration additional??
Luis Coiro
You should do switchport voice vlan 200
Alain
