12-01-2023 01:14 PM
Excuse me for this prehistoric post (my boss is a little stingy).
I received, today (01/december/2023) a refurbished switch WS-C3750V2-24TS-E (built in ... 2010).
The switch doesn't boot:
"Error loading "flash:/c3750-ipservicesk9-mz.122-55.SE5.bin"
The prompt is "switch:".
With a "dir flash", I obtain a directory:
2 drwx 512 <date> c3750-ipservicesk9-mz.122-50.SE1
All other "dir" in this directory shows files for web site, but none with ".bin" extension.
I've downloaded a "c3750-ipservicesk9-mz.122-55.SE6.bin", but how to put it in the flash card (I know next how to modify BOOT using SET) ?
In
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/41845-192.html
I've found it's possible with hyperterminal (and copy xmodem), but with my Windows 10, hyperterminal does not exist anymore.
I've opened the switch, but don't have see a flash card to remove and insert in a card reader.
How to solve my problem, without send back this magnificent switch to my supplier, more than 1000 km from home ?
Thanks for all.
Best regards.
12-01-2023 02:07 PM
Looks like the switch installed tar files
2 drwx 512 <date> c3750-ipservicesk9-mz.122-50.SE1 < -- this is directory you need to look inside that folde bin file
try
dir flash:/c3750-ipservicesk9-mz.122-50.SE1/
then try boot flash:c3750-ipservicesk9-mz.122-50.SE1/file.bin ( replace the file based on the output you see above command)
Once it boot then change the boot variable :
boot system flash:/c3750-ipservicesk9-mz.122-50.SE1/file.bin
save and reload and test it
12-08-2023 09:46 AM
Hi.
On cisco site, I've downloaded c3750-ipservicesk9-mz.122-55.SE6.bin.
Then, with tera term, the serial cable and xmodem, I've loaded c3750-ipservicesk9-mz.122-55.SE6.bin to the flash:
On the switch:
switch: copy xmodem: flash:c3750-ipservicesk9-mz.122-55.SE6.bin
and immediatly on tera term: file \ transfer \ xmodem \ send: select the c3750-ipservicesk9-mz.122-55.SE6.bin on the computer
Then the switch is booting without problem.
Thanks for all.
