VTP VLAN configuration not allowed when device is not the primary server for vlan database.
iroperto1
How to fix this issues on Cisco 4510.
from user configuration mode type (vtp primary vlan). then you will be able to create the vlan successfully.
Deepak Kumar
Try with "VTP Primary" command on exec mode. It will give you the permission to create VLAN for the VTP domain.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
10 Replies 10
Francesco Molino
Did you tried typing the command vtp primary vlan in exec mode (not in configuration mode)?
What message did you get when you typed in this command?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Yes, that resolved my issues successfully.
Deepak Kumar
Deepak Kumar
Deepak Kumar,
Hii!!...
I have 2 Cisco 3750 switches with VTP version 3, when executing vtp status I see this:
:::::::::::::: 3750-1 ::::::::::
swcore-unioncoop-1#sh vtp status
VTP Version capable : 1 to 3
VTP version running : 3
VTP Domain Name : domain3750
VTP Pruning Mode : Disabled
VTP Traps Generation : Enabled
Device ID : c414.3cde.5c80
Feature VLAN:
VTP Operating Mode : Server
Number of existing VLANs : 15
Number of existing extended VLANs : 0
Configuration Revision : 28
Primary ID : c414.3cde.3780
Primary Description : swcore-unioncoop-2
MD5 digest : 0xFD 0xF4 0x3E 0x1C 0x5E 0xB0 0xA0 0x1A
0xB9 0x61 0xD3 0xFB 0xF1 0x8E 0xEE 0x61
Feature MST:
VTP Operating Mode : Transparent
Feature UNKNOWN:
swcore-unioncoop-1#
::::::::::::: 3750-2 :::::::::::::::
swcore-unioncoop-2#sh vtp status
Device ID : c414.3cde.3780
Feature VLAN:
Feature MST:
Feature UNKNOWN:
I understand that my 3750 switch 2 is the primary one, but when trying to create a vlan I get the error "VTP VLAN configuration not allowed when device is not the primary server for vlan database."
what could be happening?
You need to delete the (vlan.dat) file from the switch
Bro u just change version 3 to 2 then try i should work.
tq
hiii deepak
you have suggest is correct.
we need to go exce mode and put vtp primary cammand it is working for creation and deletion vlan
Rolf Fischer
Level 9
Level 9
I'd recommend to check first if you already have (or had) a primary server in your VTPv3 domain.
The 'Feature VLAN' section of the 'show vtp status' output should show you the ID and description (hostname) of the (last) primary server. As already stated in the posts above you can define one (and only one) primary server in exec mode; keep in mind that this role is not reboot-persistent, so it might got lost when the switch was reloaded the last time.
Rollf
I know, that's I figure out the switch was in production.
Andrew Dim
Have you tried VTP Mode Off in the config mode?
