Switch Cisco 9200L QOS informations
ddelay
Hi everybody
i have a simple question about QOS on switch CISCO 9200L
I have disable QOS with this two commands:
no auto qos trust (for all ports)
no auto qos global compact
ok all port has not QOS.
However, it still this big text on my switch after that and i can't delete that :
table-map AutoQos-4.0-Trust-Cos-Table
 default copy
class-map match-any AutoQos-4.0-Output-Multimedia-Conf-Queue
match dscp af41  af42  af43
match cos  4
class-map match-any system-cpp-police-topology-control
  description Topology control
class-map match-any system-cpp-police-sw-forward
  description Sw forwarding, L2 LVX data, LOGGING
class-map match-any AutoQos-4.0-Output-Bulk-Data-Queue
match dscp af11  af12  af13
match cos  1
class-map match-any system-cpp-default
  description Inter FED, EWLC control, EWLC data
class-map match-any system-cpp-police-sys-data
  description Learning cache ovfl, High Rate App, Exception, EGR Exception, NFL SAMPLED DATA, RPF Failed
class-map match-any AutoQos-4.0-Output-Priority-Queue
match dscp cs4  cs5  ef
match cos  5
class-map match-any system-cpp-police-punt-webauth
  description Punt Webauth
class-map match-any AutoQos-4.0-Output-Multimedia-Strm-Queue
match dscp af31  af32  af33
class-map match-any system-cpp-police-l2lvx-control
  description L2 LVX control packets
class-map match-any system-cpp-police-forus
  description Forus Address resolution and Forus traffic
class-map match-any system-cpp-police-multicast-end-station
  description MCAST END STATION
  description Transit Traffic and MCAST Data
class-map match-any system-cpp-police-l2-control
  description L2 control
class-map match-any system-cpp-police-dot1x-auth
  description DOT1X Auth
class-map match-any system-cpp-police-data
  description ICMP redirect, ICMP_GEN and BROADCAST
class-map match-any system-cpp-police-stackwise-virt-control
  description Stackwise Virtual
class-map match-any non-client-nrt-class
class-map match-any system-cpp-police-routing-control
  description Routing control and Low Latency
class-map match-any system-cpp-police-protocol-snooping
  description Protocol snooping
class-map match-any AutoQos-4.0-Output-Trans-Data-Queue
match dscp af21  af22  af23
match cos  2
class-map match-any system-cpp-police-dhcp-snooping
  description DHCP snooping
class-map match-any system-cpp-police-system-critical
  description System Critical and Gold Pkt
class-map match-any AutoQos-4.0-Output-Scavenger-Queue
match dscp cs1
class-map match-any AutoQos-4.0-Output-Control-Mgmt-Queue
match dscp cs2  cs3  cs6  cs7
match cos  3
policy-map AutoQos-4.0-Output-Policy
class AutoQos-4.0-Output-Priority-Queue
  priority level 1 percent 30
class AutoQos-4.0-Output-Control-Mgmt-Queue
  bandwidth remaining percent 10
  queue-limit dscp cs2 percent 80
  queue-limit dscp cs3 percent 90
  queue-limit dscp cs6 percent 100
  queue-limit dscp cs7 percent 100
  queue-buffers ratio 10
class AutoQos-4.0-Output-Multimedia-Conf-Queue
class AutoQos-4.0-Output-Trans-Data-Queue
class AutoQos-4.0-Output-Bulk-Data-Queue
  bandwidth remaining percent 4
class AutoQos-4.0-Output-Scavenger-Queue
class AutoQos-4.0-Output-Multimedia-Strm-Queue
class class-default
  bandwidth remaining percent 25
  queue-buffers ratio 25
policy-map AutoQos-4.0-Trust-Cos-Input-Policy
class class-default
  set cos cos table AutoQos-4.0-Trust-Cos-Table
policy-map system-cpp-policy
My question: what is it ? it's just a basic qos information if i want to manage QOS on my all port? or this qos is already active in my switch? if the last suggestion, why i delete all QOS on 9200L ?
For your information, before my switch i have a sophos XG, i manage my qos with that today
Ps: sorry for my english :)
Thx all
David
as far as I recall, your only option is to remove these lines manually...
hi, thx for your reply :) !!
just i have delete all manualy on my file config ? or there is a command for delete on CLI ?
thx
