Switch cisco C1000 went to stack mode on its own
Translator
Community Manager
Community Manager
We have a Cisco C1000 switch that went into stack mode alone. I turned on the switch to modify some console settings and I have this message:
*Mar 1 00:00:13.582: %STACKMGR-4-SWITCH_ADDED: Switch 1 has been ADDED to the stack
*Jun 17 13:48:00.487: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Jun 17 13:48:01.364: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Jun 17 13:48:04.584: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan60, changed state to down
*Jun 17 13:48:04.679: %SYS-5-CONFIG_I: Configured from memory by console
*Jun 17 13:48:04.804: %STACKMGR-5-SWITCH_READY: Switch 1 is READY
*Jun 17 13:48:04.804: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
*Jun 17 13:48:04.804: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state DOWN
*Jun 17 13:48:05.177: %STACKMGR-5-MASTER_READY: Master Switch 1 is READY
*Jun 17 13:48:05.258: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1000 Software (C1000-UNIVERSALK9-M), Version 15.2(7)E1, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Sat 07-Dec-19 09:15 by prod_rel_team
*Jun 17 13:48:05.339: %SSH-5-ENABLED: SSH 2.0 has been enabled
Afterwards I can't type anything on the switch and even when I try to reset with the mode button, it won't let me.
I have a backup, so no worries to make a factory reset, but how to do it?
Thank you in advance
balaji.bandi
Is this standalone switch, or part of the stack. ? what version code running ?
did you get # prompt or >
Try Factory reset :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst1000/hardware/installation/8_16_port_hig/b_c1000_8_16_hig/configuring_the_switch.html
BB
l33dsunited82
*Mar 1 00:00:15.966: %STACKMGR-4-SWITCH_ADDED: Switch 1 has been ADDED to the stack
*Mar 1 00:00:19.326: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Jun 7 09:37:23.399: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Jun 7 09:37:23.895: %PNP-6-PNP_DISCOVERY_STARTED: PnP Discovery started
*Jun 7 09:37:26.750: %SYS-5-CONFIG_I: Configured from memory by console
*Jun 7 09:37:26.988: %STACKMGR-5-SWITCH_READY: Switch 1 is READY
*Jun 7 09:37:26.988: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
*Jun 7 09:37:26.989: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state DOWN
*Jun 7 09:37:27.230: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1000 Software (C1000-UNIVERSALK9-M), Version 15.2(7)E6, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2022 by Cisco Systems, Inc.
Compiled Tue 22-Mar-22 10:25 by mcpre
*Jun 7 09:37:27.236: %STACKMGR-5-MASTER_READY: Master Switch 1 is READY
*Jun 7 09:37:27.374: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Jun 7 09:37:28.731: %LINK-5-CHANGED: Interface Vlan1, changed state to administratively down
*Jun 7 09:37:30.912: %USB_CONSOLE-6-MEDIA_RJ45: Console media-type is RJ45.
*Jun 7 09:37:32.494: %PNP-6-PNP_BEST_UDI_UPDATE: Best UDI [PID:C1000-24P-4G-L,VID:V02,SN:FOC2707YFE5] identified via (master-registry)
*Jun 7 09:37:32.494: %PNP-6-PNP_CDP_UPDATE: Device UDI [PID:C1000-24P-4G-L,VID:V02,SN:FOC2707YFE5] identified for CDP
*Jun 7 09:37:32.496: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)
I had to wait for the switch left it overnight cam back in the morning and got to # prompt from there i deleted some flash: files and it still says stack when loading can't get rid of it but it will be a stand alone switch so not too worried.
