Hi there,
From what I have seen, the default subnet after rest is 10.0.0.0 /24 . I believe the VLAN 1 SVI will be 10.0.0.1, but you should be able to check the ARP cache on your laptop to see what other IPs are transmitting when you connect it to the switch.
cheers,
Seb.
