SWITCH configuration
Hi, I have problem why i can't ping the default-gateway of the new switch which i can configure using copy paste of SH RUN to the old switch. But i have a connection of the network because i can sent email and somebody can remote me but the default-gateway i cannot ping and when i  sh vlan, not all active vlan showing like in the old switch to much vlan showing when i type sh vlan. Please help me what is the lucking of my configuration. Thanks
2 Accepted Solutions
InayathUlla Sharieff
Not sure if the ports are up which inturn makes the vlan active.
Kindly check one of the vlans:-
example:-
show vlan id 10 >> then see if one of the interface is active.
REgards
Inayath
Sounds like,you can't get to the management SVI of the switch.If the replacement is  same part number as old,have a look and make sure that you have the vlan created/defined and the svi is not shut down.Please fee to post the config without credentials and happy  to take a quick look at it
***Please rate all the useful posts***
-Prabath
example:-
REgards
Inayath
-Prabath
