Switch configuration
chmoschos
Community Member
hi,i am litle confused on this..
on a switch when you add the following commands on line vty configuration mode
login local
transport input telnet ssh
username name password pass
the user can login to switch via ssh and the switch will prompt for a username and password right?
when a user using telnet will be prompted only for the password?
will a telnet user be able to logon?
thanks
Richard Burts
Charalambos
In that configuration telnet will prompt for username as well as password. (The behavior of SSH and Telnet will be the same for this configuration.)
Rick
Rick
thanks you for your time
my best regards
