Switch connectivity
LAXCIS_2
Community Member
We are setting up a brand new network. We have a 3850 as our core switch, and then 4 other edge switches (2960X). The edge switches are connected to the core 3850 switch via 10g fiber. I have vlans setup for various segments. The network mgmt vlan is 10. I have this configured on the core switch with an ip, and also on our edge switches with an ip. I cannot ping from the core switch to any edge switches. I know the vlan 10 is up and running. When I do a sho cdp neighbor on the core switch, I do see all the edge switches. I also have a few other devices plugged into the edge switches but cannot ping these devices either. Help!
dmuinoorallo
Level 4
Level 4
You need check the next steps:
1- The vlan 10 is created.
2- The vlan 10 is asignated to minimun one port in each switch
3- In all switches vlan 10 isn't native vlan
4- All ports between switches are trunks(with vlan 10 permit) or are in access mode(with these port in vlan 10 in each router)
5- default gateway is correctly configure in all switches.
Please check this steps and tell us your results.
Joseph W. Doherty
Are the inter switch link interfaces defined as trunks?
LAXCIS_2
Community Member
For whatever reason, the vlans on the core switch were not created even though I see them listed in the running config. After creating them, all is good.
dmuinoorallo
Level 4
Level 4
