Switch crash
g.leonard
Level 4
Level 4
3750G switch crashed with following error:
Debug Exception (Could be NULL pointer dereference) Exception (0x2000!)
Any ideas?
Prashanth Krishnappa
Will meed more details including complete crashinfo and show version.
Bit more info:
Sep 25 2008 19:30:17 PLATFORM_RPC 0 RESOURCE_CRASH System is unable to alloc memory for RPC
Sep 25 2008 19:40:57 PLATFORM 1 CRASHED System previously crashed with the following message:
Sep 25 2008 19:40:57 PLATFORM 1 CRASHED Cisco IOS Software, C3750 Software (C3750-IPBASE-M), Version 12.2(25)SEE2, RELEASE SOFTWARE (fc1)
Sep 25 2008 19:40:57 PLATFORM 1 CRASHED Copyright (c) 1986-2006 by Cisco Systems, Inc.
Sep 25 2008 19:40:57 PLATFORM 1 CRASHED Compiled Fri 28-Jul-06 08:46 by yenanh
Sep 25 2008 19:40:57 PLATFORM 1 CRASHED Debug Exception (Could be NULL pointer dereference) Exception (0x2000)!
Sep 25 2008 19:40:57 PLATFORM 1 CRASHED SRR0 = 0x0056B958 SRR1 = 0x00029210 SRR2 = 0x0056A1EC SRR3 = 0x00021000
Sep 25 2008 19:40:57 PLATFORM 1 CRASHED ESR = 0x00000000 DEAR = 0x00000000 TSR = 0x8C000000 DBSR = 0x10000000
Sep 25 2008 19:40:57 PLATFORM 1 CRASHED CPU Register Context:
Sep 25 2008 19:40:57 PLATFORM 1 CRASHED Vector = 0x00002000 PC = 0x00906338 MSR = 0x00029210 CR = 0x30000005
Sep 25 2008 19:40:57 PLATFORM 1 CRASHED LR = 0x00906260 CTR = 0x00000000 XER = 0xC0000075
Sep 25 2008 19:40:57 PLATFORM 1 CRASHED R0 = 0x00000000 R1 = 0x02B6DDF8 R2 = 0x00000000 R3 = 0x00000000
Sep 25 2008 19:40:57 PLATFORM 1 CRASHED R4 = 0xFFFFFFFE R5 = 0x00000000 R6 = 0x02B6DDD0 R7 = 0x00000000
Sep 25 2008 19:40:57 PLATFORM 1 CRASHED R8 = 0x00029210 R9 = 0x01660000 R10 = 0x0197F080 R11 = 0x00000000
Sep 25 2008 19:40:57 PLATFORM 1 CRASHED PC = 0x00906338, SP = 0x02B6DDF8
Sep 25 2008 19:40:57 PLATFORM 1 CRASHED R12 = 0xA0000000 R13 = 0x00110000 R14 = 0x00578E94 R15 = 0x00000000 (-1)
Sep 25 2008 19:40:57 PLATFORM 1 CRASHED R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
Sep 25 2008 19:40:57 PLATFORM 1 CRASHED R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000000
Sep 25 2008 19:40:57 PLATFORM 1 CRASHED R24 = 0x00000001 R25 = 0x00000002 R26 = 0x0053E27C R27 = 0x00000000
Sep 25 2008 19:40:57 PLATFORM 1 CRASHED R28 = 0x073F4D6C R29 = 0x000008C8 R30 = 0x00000000 R31 = 0x0000000F
Sep 25 2008 19:40:57 PLATFORM 1 CRASHED Stack trace:
Sep 25 2008 19:40:57 PLATFORM 1 CRASHED Frame 00: SP = 0x02B6DE08 PC = 0x00906238
Sep 25 2008 19:40:57 PLATFORM 1 CRASHED Frame 01: SP = 0x02B6DE10 PC = 0x005747F4
Sep 25 2008 19:40:57 PLATFORM 1 CRASHED Frame 02: SP = 0x02B6DE48 PC = 0x00578C98
Sep 25 2008 19:40:57 PLATFORM 1 CRASHED Frame 03: SP = 0x02B6DE68 PC = 0x00578F48
Sep 25 2008 19:40:57 PLATFORM 1 CRASHED Frame 04: SP = 0x02B6DE70 PC = 0x00908064
Sep 25 2008 19:40:57 PLATFORM 1 CRASHED Frame 05: SP = 0x00000000 PC = 0x008FE62C
Image text-base: 0x00003000, data-base: 0x00EE3E54
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEE4, RELEASE SOFTWARE (fc1)
EGH-Floor1-1 uptime is 43 weeks, 3 hours, 23 minutes
System restarted at 11:12:49 GMT Fri Nov 30 2007
System image file is "flash:c3750-ipbase-mz.122-25.SEE2/c3750-ipbase-mz.122-25.SEE2.bin"
cisco WS-C3750G-48PS (PowerPC405) processor (revision F0) with 118784K/12280K bytes of memory.
Processor board ID
Last reset from power-on
1 Virtual Ethernet interface
104 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:19:56:98:96:00
Motherboard assembly number : 73-10216-08
Power supply part number : 341-0108-03
Motherboard serial number :
Power supply serial number :
Model revision number : F0
Motherboard revision number : B0
Model number : WS-C3750G-48PS-S
System serial number :
Top Assembly Part Number : 800-26853-01
Top Assembly Revision Number : A0
Version ID : V05
CLEI Code Number :
Hardware Board Revision Number : 0x09
Switch Ports Model SW Version SW Image
1 52 WS-C3750G-48PS 12.2(25)SEE2 C3750-IPBASE-M
* 2 52 WS-C3750G-48PS 12.2(25)SEE2 C3750-IPBASE-M
Switch 01
Switch Uptime : 19 hours, 58 minutes
Base ethernet MAC Address : 00:19:56:85:7D:00
Top assembly part number : 800-26853-01
Top assembly revision number : A0
Version ID : V05
CLEI Code Number :
Configuration register is 0xF
Adam Frederick
Level 6
Level 6
2 best options;
1.) Upgrade IOS
2.) Contact TAC
