Bookmark
Subscribe
866
switch has two default ip route.what happens when one router down
getaway51
Level 2
Level 2
I have switch with 2 ip routes. reason is because i have 2 router.
ip route 0.0.0.0 0.0.0.0 10.1.1.1
ip route 0.0.0.0 0.0.0.0 10.1.1.2
If 10.1.1.2 is down, will switch still sending traffic to 10.1.1.2?
7 Replies 7
Hello
 Yes /No depending if the physical interface actually registers its link down otherwise the traffic will blackholed
Kind Regards
Paul
any sample config?
Hello
sample config regards what?
Kind Regards
Paul
Utilising a dynamic routing protocol instead of using hard coded static/default routes will help you find a resolution. Dynamic routing protocols will converge when a link/router goes down to find an alternative path for traffic and to avoid any failures. You can also manipulate these protocols to weight/favour links. This all depends on your situation of course..
Many Thanks
George
Alan Ng'ethe
Level 3
Level 3
Or you can use ip sla, like this
That way, when 10.1.1.1 goes down, after a certain period traffic begins to be sent to 10.1.1.2.
Remember to rate helpful posts and/or mark as a solution if your issue is resolved.
What is the command to monitor the active interface and the sla timer?
Hello
If you wish to see sla details you can use:
sh ip sla statistics x  - sla number  optional
Kind Regards
Paul
